Thread: Klimaire mini split installation
19-05-2009, 12:56 PM #1
I work on small units in coolers, freezer ect. I am installing a Klimaire mini split heat pump in the inlaws house. The condesner ia about 9 ft from the indoor unit. The lines are about 15 ft in length. Can I leave a coil(s) in the lines to make the length to the condenser fit. I dont feel like postioning the condenser further away. Any info would be appreciated.
19-05-2009, 03:18 PM #2
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: Klimaire mini split installation
Yes you can, but you also could cut lines to measure and make new flared joint (I suppose that you have all necessary tools and knowledge).
19-05-2009, 07:21 PM #3
Yes I could do that. I have the tools and knowledge. That would require that I reduce the refrigerant charge, correct? Being a blend, I would prefer not to do that.
19-05-2009, 07:51 PM #4
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Mini split load method
By Acrisoft in forum Air ConditioningReplies: 5Last Post: 18-12-2010, 02:33 PM -
Mini split system heating, but not cooling well.
By tirider in forum Heat PumpsReplies: 7Last Post: 06-11-2009, 09:17 PM -
Mini split right installation technique
By Acrisoft in forum Air ConditioningReplies: 12Last Post: 16-05-2009, 11:33 PM -
Split mini system
By hitecnot in forum FundamentalsReplies: 1Last Post: 13-05-2008, 08:21 PM -
Q: Piping installation for Split Types
By brianubaldo in forum RefrigerantsReplies: 11Last Post: 30-04-2008, 02:23 PM
