Thread: inverter
18-05-2009, 02:31 AM #1
inverter
What the weakness from the system inverter?
18-05-2009, 03:03 AM #2
Re: inverter
There are several threads in the forum that talks about inverters, such as the one below.
http://www.refrigeration-engineer.com/forums/showthread.php?p=145310#post145310
Generally here are some of the industry observations.
- Electromagnetic interference issues
- Capacity output is between 40-100% due to oil return limitations
- The thread I gave above talks about inverter board troubles, reliability, and serviceability
- inveter and motor switching loss
18-05-2009, 03:42 AM #3
Re: inverter
thx, mekaniko5
19-05-2009, 06:13 PM #4
Re: inverter
Are the inverter boards a compressor manufacturer part, or made by the air con unit manufacturer, or by an independent supplier of boards?
This is really asking if there is any commonality between brands, or are some inverter boards more reliable than others?
Thanks.
20-05-2009, 06:00 PM #5
Re: inverter
For air conditioning split systems & VRF systems the manufacturer supplies the inverter board & any other components in the inverter circuit like capacitors, resistors & IPM module.
But most the components are standard items.
I often heath check VRF systems with over 50,000 compressor run hours on the clock & still running with original compressor & inverter.
Testing Inverters
By fridge doctor in forum Air ConditioningReplies: 38Last Post: 15-06-2011, 06:52 AM -
daikin L0 inverter problem
By robin r33 gtr in forum Air ConditioningReplies: 17Last Post: 11-03-2010, 11:25 PM -
600w inverter powerful enough??
By polly in forum Trouble ShootingReplies: 4Last Post: 21-02-2010, 10:25 AM -
Daikin Inverter Board / Compressor issues
By Greengrocer in forum Air ConditioningReplies: 12Last Post: 21-04-2009, 10:12 PM -
Sensible Heat Factor / capacity of Inverter split Systems at part load?
By Greengrocer in forum Technical SpeculationsReplies: 31Last Post: 09-02-2009, 04:57 PM
