    Nov 2006
    At home
    181
    1/4" sight glass on 1 1/8" L Line
    hi guys, we are currently installing some systems on a site where we had no input into the kit/components selection.
    basically this company has sent us 1/4" soldered type moisture indicator/sight glass. being installed are 1 1/8" Liquid lines, now they say use reducing "T" pieces (1 1/8" x 1 1/8" x 1/2" with 1/2" to 1/4" reducer) to install the sight glass "parallel" to the liquid line. they say ensure the sight glass is installed at "highest" gravitational point to ensure anye bubbles in LL will flow into the sight glass and wont bypass it to give false indication,
    i can understand the theory behind it because if you had say 2 1/8" liquid line or 3 1/8" i don't even think a sight glass that big exists, at least the biggest danfoss do is 1 1/8" from what i can see.
    is this common practice?
    i know the easiest thing to do is just buy 1 1/8" sight glass but they refuse! lol, i also know i should just get on with it because thats how they want it but i cant help but get some other opinions.
    --0-- Sight Glass 1/4"
    --------------- Liquid Line 1 1/8"
    ( sorry, ignore the ... i had to put them in to make it line up correctly,hope you all understand :-/ )
    thanks for any input, btw its a bit late to change anything as this starts monday!
    Split Croatia
    6,151
    Re: 1/4" sight glass on 1 1/8" L Line
    Check last page at bottom here! Model 3780.
    Nov 2006
    At home
    181
    o.k lol, so they do exist bigger than 1 1/8" (28mm). what about the install i have been asked to do, any opinions?, essentially the sight glass will be installed horizontally above the horizontal liquid line.
    Split Croatia
    6,151
    Quote Originally Posted by SkyWalker View Post
    I don't have opinion since I did not ever done or see that.
    You did not looked carefully. Model 3780 is brazed direct on pipe. Just drill hole in pipe and braze sight glass.
    ireland
    1,450
    skywalker
    i've seen this and done it myself plenty of times, usually the 1/4 lines are drilled and brazed directly to the pipe so the way they suggest is better!
    it's also cheaper to buy a 1/4 sightglass and there in lies your price; to install
    al
    Nov 2006
    At home
    181
    thanks for the reply al, im pleased this is done by other people. will install in confidence now, cheers mate
    ireland
    1,450
    no bother mate.
    al
    Mar 2009
    KZN, South Africa
    64
    2,212
    Perhaps a silly question.
    With the sight-glasses being installed at the highest point, after teeing off the large line before & after - would these not perhaps develop a gas pocket eventually? In other words - a gas lock.
    The sight-glass socket sets which sit directly on the main line, would be a better idea, in my view.
    Nov 2006
    At home
    181
    and myn but the company we working for wont budge, they say this is common practice and it saves £
    Sep 2003
    ISRAEL
    72
    4,248
    Using 1\4 sight glasses brazed on top of any size liquid line is the quickest and cheapest way.
    May 2008
    170
    Have seen these in chillers but they are not at the highest gravitational point. In fact they are probably at the lowest point.
  1. Superheat and Subcooling
  2. Odd view in a sight glass
    By dkemper in forum Trouble Shooting
    Last Post: 16-06-2010, 12:10 PM
  3. Leaking sight Glass!?!!
    By The MG Pony in forum Fundamentals
    Last Post: 19-04-2007, 06:09 AM
  4. liquid line sight glass mystery
    By austech in forum Technical Discussions
    Last Post: 18-07-2006, 08:16 PM
  5. Sight Glass Located
    By Abe in forum Trouble Shooting
    Last Post: 22-01-2002, 01:22 AM
