Results 1 to 9 of 9
    richard1900's Avatar
    richard1900 Guest
    do u need an accumulator on a chiller?
    do u need an accumulator on a chiller? Is there a way to omit the accumulator on a chiller?
    Apr 2001
    72
    5,069
    28
    Re: do u need an accumulator on a chiller?
    Accumulators are needed where reduction in heat load can result in floodback to the compressor. On most systems they are not needed... so the answers to your questions are: maybe and maybe.
    Mar 2006
    Merate (LC) - Italy
    2,553
    On a water chiller, it is seldom used. I can say that none of the primary chiller manufacturers I know of install accumulators on the suction.
    May 2006
    India
    68
    400
    12
    Load variation is main issue. Most chiller manufacturers do it out of abudent pre-caution against floodback since load variation is out of their control when chiller is delivered to customer.
    Mar 2009
    ireland
    87
    9
    water chiller? blast chiller??
    constant load no
    vari load yes..... but it will not do any harm to fit one ..any thing that stops liquid is a good thing
    Nov 2008
    India
    34
    12
    It is used for safety purpose. If there is a variable load on evaporator accumulator is used. For small capacity water chiller accumulator is rarely used. To omit accumulator, u use thermostatic expansion valve, to feed the evaporator according to load.
    Jan 2008
    India
    64
    172
    11
    If you are talking of Water / brine chiller accumulators are not needed.
    If it is cold room refrigeration system accumulators may be required.
    Sep 2003
    ISRAEL
    66
    4,119
    38
    It all depend on design and working conditions.
    Some manufacturers have them and some don't.
    Jul 2010
    usa
    34
    yes i need this thanks for this post
  1. process chiller help
    By talon771 in forum Industrial
    Last Post: 12-01-2011, 09:42 PM
  2. Dunham Bush Chiller Alarm
    By Regulator in forum Air Conditioning
    Last Post: 08-12-2010, 02:42 AM
  3. Absorption Chiller VS Mech. Chiller
    By Intern in forum Industrial
    Last Post: 30-05-2009, 08:31 AM
  4. york chiller motor rotation error
    By cesarnino in forum Trouble Shooting
    Last Post: 13-12-2008, 04:43 PM
  5. Trane CVHE 450 R11 Centrifugal Chiller
    By albertjoseph in forum Air Conditioning
    Last Post: 06-10-2008, 03:23 PM
