Results 1 to 8 of 8
Thread: Oil additive!
13-05-2009, 01:33 AM #1
Oil additive!
Gentlemen, and Ladies of course, comments please on the attached link? Just another con or the real deal?
http://www.usrefrigerationtech.com/index.php
13-05-2009, 02:37 AM #2
Re: Oil additive!
Increases efficiency of evaporators by 73%!
Lowers the boiling point of all refrigerants!
Compatible with all oils!
With results like these Trane and York will be using by next week, assuming all is as presented.
13-05-2009, 03:27 AM #3
Re: Oil additive!
Do I detect some sarcasm per chance?
13-05-2009, 03:45 AM #4
Re: Oil additive!
It is a scam. I didn't find in ASHRAE handbook that efficiency of the plant will be reduced year after year.
If it is real energy savings, people should show the estimation (numbers) to compare before and after. Instead we see many questionable customers and chemical analyses of the oil.
13-05-2009, 03:58 AM #5
Re: Oil additive!
Most of these gimmics end up causing other system problems.
Wonder where the carbon & sludge disappear to.
13-05-2009, 04:20 AM #6
Re: Oil additive!
Don't disagree with anything said so far...
19-05-2009, 04:43 PM #7
Re: Oil additive!
Many people look for magic solutions of energy saving issue. However, the best way to save energy is optimization(design or/and operation) of the refrigeration plant.
20-05-2009, 09:32 PM #8
Re: Oil additive!
I agree, I see that this topic has been covered in other threads with the same results.
I found this on the web
By tonyhavcr in forum FundamentalsReplies: 2Last Post: 02-03-2008, 03:42 AM -
additive and mirocprosser question
By jayjay in forum Technical DiscussionsReplies: 8Last Post: 18-04-2006, 09:44 AM
