12-05-2009, 05:30 PM #1
Alco/Emerson head master/condensor pressure control
Hello friends of refrigeration,
I've been told that Alco/Emerson is eliminating some "HP" & HPC" head master/condensor pressure control 3-way valves and we are to switch to another brand. Well, I do alot of R134a and Alco/Emerson offered pressure control points at 100psi, 110psi, and 125psi. I only find the alternate source having 100psi. Does anyone know or care about controling the condensor pressure at slightly higher pressures. I would go with the slightly higher pressure if I had a long remote hot gas run for defrost and slightly oversided condensing unit. Thanks, Joe
13-05-2009, 01:50 PM #2
Re: Alco/Emerson head master/condensor pressure control
Thanks for the response,
I believe Sporlan LAC series is only set fopr 100 psi.
Head Pressure control valve
By Lertpol in forum New TechnologiesReplies: 7Last Post: 27-04-2010, 11:24 AM -
head pressure control
By wing in forum New TechnologiesReplies: 2Last Post: 29-04-2009, 02:11 PM -
Condenser Head Pressure Control
By u856684 in forum IndustrialReplies: 0Last Post: 28-05-2008, 09:40 PM -
Capacity Control Head
By abbasi in forum FundamentalsReplies: 11Last Post: 07-05-2005, 12:25 PM -
New Capacity Control Solution
By embrown in forum New TechnologiesReplies: 19Last Post: 30-12-2003, 01:33 PM
