Results 1 to 2 of 2
    Oct 2004
    65
    Alco/Emerson head master/condensor pressure control
    Hello friends of refrigeration,
    I've been told that Alco/Emerson is eliminating some "HP" & HPC" head master/condensor pressure control 3-way valves and we are to switch to another brand. Well, I do alot of R134a and Alco/Emerson offered pressure control points at 100psi, 110psi, and 125psi. I only find the alternate source having 100psi. Does anyone know or care about controling the condensor pressure at slightly higher pressures. I would go with the slightly higher pressure if I had a long remote hot gas run for defrost and slightly oversided condensing unit. Thanks, Joe
    Oct 2004
    65
    Re: Alco/Emerson head master/condensor pressure control
    Thanks for the response,
    I believe Sporlan LAC series is only set fopr 100 psi.
  1. Head Pressure control valve
    By Lertpol in forum New Technologies
    Last Post: 27-04-2010, 11:24 AM
  2. head pressure control
    By wing in forum New Technologies
    Last Post: 29-04-2009, 02:11 PM
  3. Condenser Head Pressure Control
    By u856684 in forum Industrial
    Last Post: 28-05-2008, 09:40 PM
  4. Capacity Control Head
    By abbasi in forum Fundamentals
    Last Post: 07-05-2005, 12:25 PM
  5. New Capacity Control Solution
    By embrown in forum New Technologies
    Last Post: 30-12-2003, 01:33 PM
Tags for this Thread
