    nishant's Avatar
    nishant Guest
    AC Market Segmentation - Where are VRFs?
    Hello all,
    I am doing research on India Air conditioning Market and currently i am working on segmenting the market.
    I have arrived at dividing the market into room and central air conditioners.
    Room - Window and Splits
    Central - Ducted splits, Packaged , Central plant and Chillers
    I am not able to figure out where does the VRF system come under? Can someone please help?
    Aman
    tmranjit's Avatar
    tmranjit Guest
    Re: AC Market Segmentation - Where are VRFs?
    VRF will fall in centralised A/C segment
    Quote Originally Posted by nishant View Post
    Hello all,
    Aman
    nishant's Avatar
    nishant Guest
    Thanks for the reply.
    But i see not much difference in the configuration of multi-split ACs and VRFs. The obvious difference is technology.
    VRFs are one outdoor unit linked to many indoor units unlike multi-split ACs which have 2 or 3 indoor units.
    Can you please further explain?
    Thanks and Regards
    Aman
    Nov 2006
    At home
    181
    you have basically answered your own question, vrf mean less space outdoors, means less electrical circuits, should mean less pipework so less labor to install.
    if it is "3 pipe heat recovery" then your looking at some great efficiency ratios as the system can take heat from one area and eject it in another area where its needed, essentially recycling the buildings heat load.
    one obvious downside is if you loose major components outdoors you loose a good amount if not all of you cooling capacity until problem is rectified.
  1. Replies: 10
    Last Post: 13-06-2008, 05:57 AM
  2. how to find niche market
    By Lc_shi in forum Technical Discussions
    Last Post: 18-05-2008, 09:55 AM
  3. Refrigerant Market in Germany
    By frigo-ice in forum Legal-Business-Marketing
    Last Post: 17-01-2008, 08:54 PM
  4. market share industrial refrigeration
    By starbucks123 in forum Legal-Business-Marketing
    Last Post: 04-07-2007, 11:06 PM
  5. All Brands Spares Market
    By Seenu in forum Air Conditioning
    Last Post: 31-05-2007, 07:57 PM
