    Mar 2009
    Mancheser
    41
    55
    Basic question about recovering
    Hello all,
    Im still new to this scene and am Still learning about everything, and would be gratefull of any advise given. Just a few quick questions of things I am a little unsure of:
    First of all, When Recovering do I recover just into the vapour valve on the recovery cylinder or liquid? Or do I swap over accordingly?
    Also what is the correct way to determine the condenser operating temp? (The unit I am currently working on is a lennox package with R407c.)To work out my pressure test value when leak detecting.
    Hope this makes sense, Thanks in advance for any help given
    11,025
    Re: Basic question about recovering
    If you are recovering with a single hose, not doing a push/pull, then it doesn't matter which valve you use. It all ends up in the same place.
    Mar 2009
    Mancheser
    41
    55
    Ar Thanks Brian,
    Thats what I thought it was just for piece of mind check Im doing the process correctly.
    Feb 2001
    Doncaster, England
    199
    Hi lees8110,
    To work out the minimum leak test pressure, you would use the values from the table in BS EN 378:2008, which are for UK,
    High side with air cooled condenser 55C
    High side with evaporative condenser 43C
    Low side 32C
    So you need to work out the saturation pressure of the refrigerant for those temperatures. Note use the liquid scale on your comparator.
    Tony
    Split Croatia
    57
    6,151
    36
    For Fujitsu R407 VRF leak test pressure is 2,94MPa for 24 hours. Change of pressure with temperature is 0,01Mpa/1K
    Mar 2009
    Mancheser
    41
    55
    Spot on tony thanks for that
    I remember doing it now,
    thanks again
  1. Carrier chiller basic board problem
    By noushad123 in forum Trouble Shooting
    Last Post: 17-06-2010, 06:55 AM
  2. basic fridge question
    By weidit in forum Fundamentals
    Last Post: 08-05-2009, 07:52 AM
  3. r134a question, calculating heat lost by refrigerant
    By kamikazi929 in forum Fundamentals
    Last Post: 03-01-2008, 08:19 PM
  4. Basic question about refrigerant to use
    By cbfull in forum Fundamentals
    Last Post: 07-08-2007, 02:19 AM
  5. Urgent, Kirchoff question
    By Peter_1 in forum Fundamentals
    Last Post: 20-01-2004, 03:12 PM
