Results 1 to 13 of 13
    Dec 2008
    Brazil
    106
    Mini split right installation technique
    Most service manual states to apply vacuum
    before adding fluid to the system
    In some filmes I saw in youtube, the guy install it in a simple way just by purging the air with the refrigerant itself. (no vacuum needed)
    Could anybody clarify it ?
    Which is the right way ?
    Moises
    Oct 2008
    North East
    1,050
    Re: Mini split right installation technique
    Absolutely not, it is illegal to release refrigerant into the air.
    Im sure the pros will be along soon to advise accordingly.
    Sep 2003
    ISRAEL
    72
    4,248
    Its new to me that You Tube is the new Bible for refrigeration,
    Purging is not enough and not legal,VACUUM
    Dec 2008
    Brazil
    106
    Yes
    Guys are speading lots of videos in youtube teaching
    how to install split without vacuum and this seemed wrong for me.
    I am a teacher in mechatronics not refrigeration professional, so my mission is search and spot wrong and rigth techniques to my students in several areas of electronics and mechanics
    Moises
    mistubishi-eng's Avatar
    mistubishi-eng Guest
    1. Pressure Test System Pipe work
    2. Evacuate System
    3. Add/release refrigerant as required.
    4. Commission System
    11,025
    Quote Originally Posted by mistubishi-eng View Post
    2. Evacuate System
    Incorrect, refrigerant MUST NOT BE RELEASED.
    Nov 2006
    At home
    181
    acrisoft,
    what must be realized is by vacuuming the system, yes we are "removing air" but we are also decreasing the pressure to boil off any moisture that has found it way into the sytem while the install took place, for instance at 10 Torr water will boil at approx 10'C ambiant temp.
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by SkyWalker View Post
    acrisoft,
    Not any moisture but to acceptable amount. For removal of all moisture, we would need to pump it to absolute vacuum for infinite time.
    Jul 2008
    London
    848
    Why did Japanses split manufacturers recommend purging in the install leaflet for many years and still warranty their kit?
    (They only stopped when it became considered wrong from a climate perspective not for any other reason.)
    Certain Ebay stuff still comes with the purge recommendation due to it being Chinese translated.
    Commercial fridgies always purged when a new drier or semi hermetic was fitted as std practice.
    All illegal now no doubt (at least in the UK) but not that harmful to the system and I doubt fridges/ac is more reliable now than back then.
    Sure recommend vac'ing but you'll probably find they don't have a vac pump (and even less likely, a reclaim rig come rip out time..)
    Jul 2008
    London
    848
    It's pretty bloody obvious he means add any additional OR open the valves (esp as he works for Mitsubishi Technical!)
    BTW All this faux horror gets right on my tits
    Jan 2007
    82
    Multisync!
    I am horrified at the use of the word "Tits!"
    "I'm anaspeptic, frasmotic, even compunctuous to have caused you such pericombobulation."
    11,025
    Quote Originally Posted by multisync View Post
    It might be bloody obvious to you but it was not addressed to you.
    If the poster works for Mitsubishi Technical then he has even more reason to be specific in his choice of words especially when dealing with an international readership.
    Jul 2008
    London
    848
    Sorry Brian I meant to have written that in Portuguese
  1. Mini split load method
    By Acrisoft in forum Air Conditioning
    Last Post: 18-12-2010, 02:33 PM
  2. Mini split system heating, but not cooling well.
    By tirider in forum Heat Pumps
    Last Post: 06-11-2009, 09:17 PM
  3. Split mini system
    By hitecnot in forum Fundamentals
    Last Post: 13-05-2008, 08:21 PM
  4. Q: Piping installation for Split Types
    By brianubaldo in forum Refrigerants
    Last Post: 30-04-2008, 02:23 PM
  5. High Efficiency Mini Split for High Humidity Area
    By Joybob in forum Air Conditioning
    Last Post: 07-04-2008, 11:06 PM
