Results 1 to 8 of 8
Thread: Static Regain Method
10-05-2009, 03:18 PM #1
Can anybody plz explain the static regain method for the duct design , If i can get any link or pdf i will be thankful to us
To Site moderator : Sir - Actually i am a junior engineer looking for career improvement so i try to study more points plz dont hesitate or think mistakenly that i am looking on same points.
Still i dont know to send a private message, i send through this
harsen
10-05-2009, 11:28 PM #2
Re: Static Regain Method
Harsen, we don't mind helping you but remember that this forum is primarily about refrigeration. Ductwork design is a separate field of study.
anyway...
One link for you.
http://www.air-conditioner-selection...er-sizing.html
although this one is better...
http://www.acr-news.com/news/news.asp?id=708Last edited by Brian_UK; 10-05-2009 at 11:32 PM.
10-05-2009, 11:32 PM #3
Here read this it don`t take a rocket scientist to GOOGLE something
http://ateam.lbl.gov/Design-Guide/DG...ingmethods.htm
NormMy wife used to say you never listen to a word I say at least I think that what she said
11-05-2009, 12:24 AM #4
Static regain is the simplist design, generally known trunk duct design. You have a big ars## supply duct and the fan maintains a constant static pressure and you regulate each take-off.
magoo
11-05-2009, 11:28 PM #5
12-05-2009, 05:23 AM #6
Hi Brian
Trunk duct design/ static regain is very popular with open plan offices, factories, large chillers and freezer stores, basically the trunk duct is selected for minimal duct velocity, and each take-off or outlet supply is regulated at take-off point with a damper. If application is open plan well each outlet is regulated for design air flow, whether a single supply or a multi-supply, you rush around with a diffuser hood and check each supply and regulate dampers. If variable supply diffusers then you need to allow for max flow per branch take-off and apply static supply pressure regulation for fan speed control, and split coils for cooling options if DX, or if other cooling as in air-conditioning the regulating water valve will regulate.
For example an open plan office as per a high rise bldg, the centre core areas are fixed flow, the problem starts when tennant installs individual offices, another example is a large coldstore, and a large supply duct runs down centre of space and a liniar slot diffuser/ regulator is fitted to give even airflow.
hoe this explains Magoo
12-05-2009, 11:36 PM #7
I understand all about the balancing of an air system but his question was about static regain not balancing dampers.
Designing a system with good static regain reduces the need for extensive dampering and can, in fact, reduce the number of dampers required.Brian - Newton Abbot, Devon, UK
13-05-2009, 12:16 AM #8
Static regain, to quote the Carrier design manual: Air distribution.
"The basic principle of the static regain method is to desighn a duct run so that the increase in static pressure ( regain due to reduction in velocity ) at each branch or terminal just offsets the friction loss in the succeeding section of duct. The static pressure is then the same before each terminal and at each branch. "
magoo
Leak Testing?
By Thana in forum Trouble ShootingReplies: 36Last Post: 31-08-2010, 02:57 PM -
Regarding Static Pressure
By balaji in forum Air ConditioningReplies: 8Last Post: 12-08-2008, 11:31 PM -
Method Statements
By sinewave in forum Legal-Business-MarketingReplies: 11Last Post: 01-08-2008, 06:54 PM -
Fan Static Pressure
By Samarjit Sen in forum FundamentalsReplies: 5Last Post: 27-09-2007, 02:48 AM -
Fan Static Pressure
By watana in forum Air ConditioningReplies: 3Last Post: 05-10-2003, 06:43 AM
