Thread: Chiller connectivity problem
08-05-2009, 08:00 AM #1
Friends i have a problem to connect a york millinium recip. Chiller to my pc.
Any one have any idea for this!
Which software can be use to resolve this problem.
Infact! I want to monitor and control this chiller from my pc at rs485 network.
08-05-2009, 10:52 AM #2
Re: Chiller connectivity problem
Hi ALLAHHOOPK
Firstly what is it you require the PC to do with the controller? If its to act as a simple time clock then you can interface with relays through the remote start / stop line, if you want to control setpoints etc and use as a repeater panel where you can monitor remotely then you'll probably need a BACNET , MODBUS, EMS type interface
12-05-2009, 05:57 PM #3
Dear i don't know the software, which can be use to connect the chiller miro board. Interfacing is the second step.
Thanks with regards.
Carrier chiller basic board problem
By noushad123 in forum Trouble ShootingReplies: 25Last Post: 17-06-2010, 06:55 AM -
Problem with Trane RTAD100 chiller.
By on4hf in forum Trouble ShootingReplies: 8Last Post: 14-10-2009, 09:01 PM -
York YK Chiller Problem
By icebox in forum Refrigeration BooksReplies: 13Last Post: 01-07-2008, 06:05 PM -
York Chiller Excessive Purges Problem
By imranmd in forum CommercialReplies: 5Last Post: 07-03-2008, 05:13 AM -
R11 Centrifugal Chiller Oil Problem
By iceman007 in forum Trouble ShootingReplies: 8Last Post: 17-02-2008, 02:14 AM
