Results 1 to 8 of 8
Thread: air drier munters pd/75?
07-05-2009, 01:48 AM #1
Hi has anybody had experience with this model of machine,a customer has one but has been told to use dessicant dryer more efficient and use less energy,it is being used the reclaimed brick industry,any comments appreciated thanks
07-05-2009, 10:29 AM #2
Re: air drier munters pd/75?
Give more details ; i have used desiccant wheel type dryer from carl munters with lithium chloride honeycomb wheel .
08-05-2009, 08:06 PM #3
is it efficient and how much energy will it consume /the air drier has a 5/6 hp compressor in it along with heaters 3phase ,i will try to find out more details about the machine
13-05-2009, 12:57 AM #4
sorry for delay its a mxd550 by munters itshould remove 500 ltrs in 24 hours need to find details of a dessicant machine that will do the same
10-06-2009, 03:19 PM #5
I was in a meeting with Munters about dehumidifiers in food coldrooms and how they reduce ice on the floor and doors but they didnt realise that they are drying out the food and ruining the quality by taking the moisture out of it. im sure they work wonders where they are needed tho
11-06-2009, 06:02 PM #6
What would be the lowest temperature application?
Somebody told me the Muster dryer do not work good at temperature under -20ºC
27-11-2009, 10:59 PM #7
Hi all i do is work on pd75 driers/mxd 550 which machine do you have
14-01-2011, 10:27 PM #8
yes loads of experience, the brick dust will clog up the rotor on the dessicant drier
Filter Drier
By grego in forum New TechnologiesReplies: 6Last Post: 30-05-2008, 08:32 PM -
suction line drier.
By Joeheath in forum Air ConditioningReplies: 5Last Post: 10-04-2008, 08:59 PM -
Drier
By Vincent Yu in forum FundamentalsReplies: 6Last Post: 07-02-2006, 03:02 AM -
Shelf life of an uncapped dessicant drier.
By eberg in forum Air ConditioningReplies: 2Last Post: 22-08-2001, 01:22 PM -
Drier Position
By subzero*psia in forum CommercialReplies: 8Last Post: 23-07-2001, 10:28 PM
