Results 1 to 17 of 17
    Apr 2005
    Manchester England
    43
    332
    HVAC Learning/training Dvds
    Hi there,
    Has Anyone got any training Dvds on HVAC If so Please could someone help out am willing to pay money for these to help me out with my training?
    Jan 2003
    East Anglia
    1,160
    Re: HVAC Learning/training Dvds
    Dont know of any dvd/video training methods but you may want to have a look at :-
    http://www.kotza-international.com/s...limeaudep.html
    VERY good computer training, everyone that i know who has seen it rates it highly
    Hope this helps
    Latte
    Apr 2005
    Manchester England
    43
    332
    thanks for the reply, will look into that too
    many thanks
    Oct 2001
    Nottingham UK
    5,668
    Quote Originally Posted by Latte View Post
    Hope this helps
    Latte
    What do you make of Question 4?
    Q.4
    If there is a voltage measured between the terminals of an electrical contact, then this confirms that the contact is open.
    True
    False
    Jan 2003
    East Anglia
    1,160
    Which one are you doing Frank ?
    Sorry all, not the best of links £200 !!!!!!!!!!!!!!!!!!!!!!!!, although there is a couple of quiz's in the quiz section to have a look at on the website
    good software, ok if a company is going to buy it for ongoing training but a bit over the top if you are buying it personally
    Must find my CD i got from RAC all those years back
    Latte.
    PS, Cant find a Daikin section
    Oct 2001
    Nottingham UK
    5,668
    Just looking through a few questions...........
    From my perspective, if you are measuring a voltage then you must have one lead of you meter touching neutral or earth. The other lead touches one side of the open contact and you see a voltage, then on the other side you don't. If you see a voltage on both sides of the contact then the contact is made (closed)
    Try answering the question and see what you get????????
    Maybe they measure things differently in the US, or the questions are aimed at something other than electrics? Confused - you bet.
    Jan 2003
    East Anglia
    1,160
    just had a thought (Dont mock, its 9pm and ive got to up at 5am to go to Lakeside), going slightly off topic, but does normally open and normally closed mean the same both sides of the pond. Only reason i ask is because of Franks question footnote. I seem to remember coming accross this before where we put an answer but they are looking for the opposite answer.
    Is it a terminology thing, for instance i have always called a thermostatic expansion valve as a TEV, however whilst in America a couple of months ago everyone called it a TXV.
    Latte
    11,025
    The difference between the test methods is what is confusing folks here I think.
    You will often find instructions to test if a switch is open or closed by connecting your test meter leads to both sides (contacts) of a switch (not a single point and earth).
    In this type of test if the switch is closed, contacts made, then there will not be a voltage across the contacts.
    If the switch is open , contacts broken, then there will be a voltage across the contact because the voltage is going through the meter.
    Aug 2004
    Kent /SE London
    71
    14
    The term normally open N/O this side of the pond means as the item (contactor relay etc) is taken out of the box, which ever position the contacts are in is there state ie. un-powered state. In America it is the opposite as their schematics are drawn as powered on and ours are drawn as power off.
    hope this helps
    Aug 2007
    Gosport
    64
    26
    Q.4
    True
    False
    True, because you are measuring the potential difference in the circuit between 2 contacts.
    If you place the 2 probes of a volt meter on a single piece of wire with a voltage running through the wire then you will not measure a voltage if however you (as in Q4) you place the probes between the terminals of an open contact then you will measure voltage due to the difference in potential between both terminals of the open contact
    Oct 2001
    Nottingham UK
    5,668
    Quote Originally Posted by RatsPom View Post
    I'm thinking that you put the probes of your meter across a contactor.......... feeding a motor (single phase) on the live wire.
    As the neutral also (normally) goes through the contactor, then the motor is isolated from the circuit when in the 'off' condition.
    If I can measure a voltage by putting both probes across a contactor on the hot wire in the off condition I determine something is amiss.......
    Jan 2006
    Davenport, Iowa
    11
    if you measure across nuetral to the "hot" side ; there is a potential difference and voltage will be measured; if you measure across open contacts something similar applies, there is a potenteial difference as one side of the open contact is at a lower potential than the other and if they are closed; they are at the same potential unless there is significant resistance in the "circuit" between ghe probes (or contact I.E.-burnt contacts)the vlotage meter has hgih resistance and it measures calulates it's voltage drop this assumes there is voltage resent in the circuit hope I got it right or at least close
    just a pup on the porch:)
    Oct 2008
    philippines
    36
    Hi moondawn.
    Emerson climate technologies offer free online HVAC courses. The topic offerings are fairly extensive and totally free.
    www.emersonclimate.com/onlineu
    Apr 2005
    Manchester England
    43
    332
    hi there mekaniko5
    thanks for your post i will register with them and have a look
    sounds too good to be true Free online courses!
    thank you
    Lee
    Oct 2008
    philippines
    36
    Have you tried registering?
    Apr 2005
    Manchester England
    43
    332
    hi there i have had a lot going on and aint really had the time.
    worked away for a while, am back now so will investigate it before i work away again
    cheers
    Nov 2008
    UK, Preston, PR2 8AH
    36
    are you awarded certificates if you take the exams on that website?
  1. HVAC design
    By reggie in forum Refrigeration Books
    Last Post: 26-11-2010, 04:46 AM
  2. HVAC Design Manual - free download
    By dougheret0 in forum Commercial
    Last Post: 09-11-2010, 02:57 PM
  3. HVAC Solution
    By fridg in forum Tools and Calculators
    Last Post: 25-04-2006, 02:29 AM
  4. HVAC system trend in the future
    Last Post: 17-05-2005, 08:50 AM
