Results 1 to 2 of 2
Thread: Help......
    MujtabaHH's Avatar
    MujtabaHH Guest
    Post Help......
    Hi guys
    Can I replace r417 with r134 or any other refrigerant.
    Please reply this is urgent
    Thanking you,
    Split Croatia
    57
    6,151
    36
    Re: Help......
    What is equipement used for. Describe equipement.
    R417 is direct replacemant for R22. Since R22 has wide range of usage, you should give us data about usage to give you some advice. In meantime, check Suva page for R22 retrofit guide.
