    May 2006
    India
    74
    399
    Gasket for s & t sea water condenser
    I wish to have correct specifications for gasket material for sea water cooled condenser (shell & tube type)
    d.d.koranne
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: Gasket for s & t sea water condenser
    Metallic or non metallic?
    Gasket for water-side or gas-side?
    May 2006
    India
    74
    399
    water side & non-metallic gasket specs .
    India
    688
    Heat transfer equipment design.
    by R. K. Shah, Eleswarapu Chinna Subbarao, R. A ...
    Considering the corrosive nature of sea water and the necessity to maintain the ... The plates are sealed at the periphery by Nit rile rubber gaskets. ...
    Mar 2006
    Merate (LC) - Italy
    2,549
    SMPSMP45 is referring to PHE, I assume. I don't think nitrile rubber is an option for sea water s&t condensers. Norwegian oil and gas consortium recommends Neoprene, Butyl rubber or fluoroelastomers.
    Nitrile rubber and EPDM, along with others (graphite, PTFE, aramid, carbon fiber) don't seem to be appropriate.
    As for metal gaskets, high alloy stainless steel flanges have better results with Alloy 625, 276 or 59 gaskets or titanium gaskets.
    Other alloys like 316SS or 317L or 904L shall not be used with high alloy SS flanges.
    May 2006
    India
    74
    399
    Thanks for the reply to all
  1. R410A water cooled condenser
    By K.R.Iyer in forum Fundamentals
    Last Post: 04-02-2009, 02:10 AM
  2. Condenser water causing corrosion
    By 750 Valve in forum Technical Discussions
    Last Post: 28-05-2008, 10:21 AM
  3. condenser cooling water flow
    By claude11 in forum System Optimization
    Last Post: 07-09-2007, 06:07 AM
  4. Making a simple water cooled condenser
    By The MG Pony in forum Fundamentals
    Last Post: 01-08-2007, 11:02 AM
  5. Building a wine cabinet
