Results 1 to 2 of 2
    wing's Avatar
    wing Guest
    Installing a plenum ceiling
    Hi guys
    Our current blast freezer has two floor mounted evaporaters manufactured by LU-VE Contardo,We are thinking of installing a ceiling just above them at a height of 2100mm and leaving gap at the far end for return air flow. At present we are suffering from the air flow from the 12 fans short circuiting as it hits the product,By installing a ceiling would this help?
    Feb 2009
    PAKISTAN
    43
    21
    Re: Installing a plenum ceiling
    Quote Originally Posted by wing View Post
    Hi guys
    yes
    friend if you will make fall ceiling between the floor and the ceiling in this way the supply air will make direct contact with the product and return after crossing the product ,i have installed same like that blast freezer
  1. Installing pipework for single split unit
    By electro in forum Air Conditioning
    Last Post: 05-03-2009, 06:02 PM
  2. huskey ceiling cassette
    By Slasher in forum Air Conditioning
    Last Post: 27-07-2008, 10:56 PM
  3. Puzzling ice formation on outside of walk-in freezer ceiling
    By jbannert in forum Trouble Shooting
    Last Post: 30-04-2008, 04:58 PM
  4. Installing pipes
    By tuneee in forum Fundamentals
    Last Post: 05-06-2007, 08:21 PM
