    Mar 2006
    Lancashire
    1,859
    28
    Undersized unit.
    As the title says, how what you check for an undersized unit?
    Apart from the obvious like room not getting down/up to temp.
    Things such as discharge/suction pressures, line temps Sh and SC.
    Marc
    Aug 2008
    ireland
    75
    Re: Undersized unit.
    Also high head pressure,high suction pressure
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by marc5180 View Post
    By calculating real heat load.
    These are consequence of current room conditions, which may not represent actual needed capacity.
    For example: after long period of standby, room envelope (walls, floors, ceilings) could accumulate lot of heat, and room cannot be cooled satisfactory for prolonged period, but after walls are at normal room temperature, capacity could be more than enough.
    Apr 2001
    79
    5,071
    35
    Assuming the system is functioning properly and has run for a prolonged period (cycled at setpoint for several days), you can plot a chart of percentage of run time versus a variety of outdoor conditions. You can then extropolate the point where outdoor conditions will result in 100% run time.
    Apr 2001
    79
    5,071
    35
    Technically, it is more economical to run a smaller system that can't quite keep up on the hottest day of the year, but the customer isn't going to like it. A larger system that can handle the hottest days will make him smile, even though it costs more to run on milder days than the smaller system would.
  1. Replies: 12
    Last Post: 27-03-2011, 04:12 AM
  2. SL/SB-400 Pump Down Procedures
    By absolute-zero in forum Transport
    Last Post: 29-01-2008, 09:27 PM
  3. Thermo King OptiSet
    By REEFER-TEK in forum Transport
    Last Post: 06-12-2007, 07:23 PM
  4. TK basic micro-p features and functions
    Last Post: 05-12-2007, 06:25 PM
  5. undersized unit ??
    By moondawn in forum Air Conditioning
    Last Post: 06-04-2005, 08:25 AM
