Page 2 of 2 FirstFirst 12
Results 51 to 55 of 55
  1. #51
    May 2004
    New Zealand
    69
    10
    Re: R407 C wall mount LG 7 Kw
    G'day from New Zealand Aiyub,
    I would start again, evacuate, and weigh the correct charge into the system, and then you will know you have the right amount of gas, I also think you have a faulty indoor sensor, hope this helps
    Tony
  2. #52
    Apr 2001
    2,099
    27
    Hello Tony,
    This " beast" is rearing its head up again, but youre absolutely right...... Just shows, The Kiwis got their heads screwed on right.
    I have removed all the charge, fresh charge is in..........and the unit is working swimmingly.
    But I have given the unit a head start.......I have now connected condenser fan direct, ie: it is no longer controlled by the whims of the indoor unit sensor...........( which as u say, could well be faulty)
    But I am sick to my back teeth, ( assuming it is faulty, that is ) of LG stuff playing up.........when it should be new????
    I have had three remote controllers pack up.........Yes three. The LCD displays play up.......
    Then this beast........which I refer to as the most unforgiving air con ever built.
    Why would or should you need to have a Masters Degree to comprehend the workings of an air con????
    In this case.........LG dont have the foggiest how to design an air con which uses R407C
    I rest my case.
    Other members............may shake their heads at my impertinence.............but , me...........LG and I are not in Love no more.........we are seeking a divorce.......
    And pssssssssss,, between you and I, I have a secret mistress/ girlfreind on the side !!!!
    Her name is..........Fuji.....and Mitsi !!!! but one blinked at me the other day.........her name is Tosh !!!!
  3. #53
    Dec 2001
    nottingham
    96
    23
    Wink Re: R407 C wall mount LG 7 Kw
    Daikin
  4. #54
    david mcbain's Avatar
    david mcbain Guest
    can i just ask if the low ambient controll is set correctly and that you have run this unit with a probe taking evap temp if not please could you as i am interested as to what super heat you have
  5. #55
    Apr 2001
    2,099
    27
    I think u will find the readings somewhere along the thread........This unit is not fitted with Low Ambient Kit
  1. Fujitsu wall controller
    By iceman007 in forum Air Conditioning
    Last Post: 02-03-2006, 04:32 PM
  2. R407 refrigerant
    By JCole21961 in forum Refrigerants
    Last Post: 29-08-2005, 05:25 PM
  3. R22 in a R407 system
    By Abe in forum Refrigerants
    Last Post: 20-06-2003, 08:51 AM
  4. Cold wall vs. Forced-Air, which is better?
    By pezagent in forum Technical Discussions
    Last Post: 23-05-2003, 04:34 AM
  5. Mitsu High Wall
    By Abe in forum Air Conditioning
    Last Post: 07-05-2002, 05:59 PM
