    Apr 2007
    371
    Excellent Write off LOL
    Heya everyone!
    Attended customer's house today as a outdoor Pool Heat Pump (Calorex) wasn't heating.
    First visual inspection was to find the EVP coil covered in leaves and muck, fault lamp on....possibly lost charge.
    Opened unit up to find Suction accumulator had been cut out...strange. Cobwebs everywhere, 2 inches of muck in the drip tray, filthy.
    Attached gauges to system, no pressure, pumped the system up to about 1 bar and heard glugging noise.
    I knew excactly what this was (spend alot of time with these units) so i pierced the lowest refrig pipe on the system, i had forgotten to vent the Nitogen, when i removed the piercing tool i got covered in pool water from within the system :-( NOT HAPPY.
    Ooooopppss My mistake
    Had a look over the system for any other picture opportunities and found that the compressor capacitor blown to ****.
    Obviously:
    Pool water condenser had failed.
    Pool water made its way into the refrigeration system.
    Compressor blown
    Unit written off.
    Will post some pictures up later.....good times.
    4,697
    Re: Excellent Write off LOL
    JD
    Thanks for the interesting post.
    Can you tell me as I am completely ignorant as to what these units comprise of.
    What type of condenser is used?
    Is it Shell and Tube or a Plate Heat Exchanger?
    Apr 2006
    stafford
    42
    974
    JD
    please see the pick,taken from
    http://www.calorex.com/Product_range...ction_page.htm
    only ever worked on a hand full of these myself
    Paul
    "KEEP IT COOL"
    Apr 2007
    371
    Heres the pictures from today!
    Basic pool Water condenser, should answer your question
    Compressor Capacitor
    Water Exiting system at lowest point, at roughly 1.5 bar
    Blocked Evaporator :-)
    Cut-Out Accumulator
    Water from system and dirty drip tray.
    4,697
    Thanks both!
  1. Over Charge
    By andy1967 in forum Heat Pumps
    Last Post: 17-04-2009, 09:55 PM
  2. The correct way to write CO2.
    By nic_f in forum CO2
    Last Post: 09-02-2009, 07:27 PM
  3. How to write make a study of a HVAC component?
    By wilsoncheung in forum Fundamentals
    Last Post: 16-01-2009, 09:19 PM
  4. Why Men Don't Write Advice Columns:
    By Josip in forum Chit Chat & Service Stories
    Last Post: 13-10-2007, 09:58 PM
