Thread: Iced Sightglass
28-04-2009, 05:15 PM #1
Iced Sightglass
I'm sure this is pretty common,but How do you keep frost off the sight glass ? Thanks
28-04-2009, 05:58 PM #2
Re: Iced Sightglass
That all depends, there's not much info to go on. Is it a subcooled liquid line or not.
If not it might just be a case of a blocked drier. More info please......
28-04-2009, 06:23 PM #3
Re: Iced Sightglass
If the sight glass is located after a pump down SV, it will get iced every time the system goes into pomp down.
If it is located after the filter, before the SV, it will get iced when the filter is partially blocked and liquid refrigerant is boiling in it.
28-04-2009, 07:13 PM #4
Re: Iced Sightglass
Its on the evap showing the liquid level.
28-04-2009, 08:09 PM #5
Re: Iced Sightglass
I guess your refering to a flooded system ? We use a liquid eye which is a simple perspex (clear plastic) plug which is fitted into the sight glass flange and sticks out approx 40 / 50 mm the sight glass still frosts but the plastic don`t so much so you can still see the liquid level
07-05-2009, 11:57 PM #6
Re: Iced Sightglass
As Quality said we use what is called a frost shield. A small plastic cylinder that fits into sight glass.
16-05-2009, 04:00 PM #7
Re: Iced Sightglass
normally , in this case we use non-frosting type of sight glass fitted clear acryl plug.
Back wall of fridge has iced up?
By rumpelstiltskin in forum DomesticReplies: 3Last Post: 04-12-2007, 08:23 PM -
Iced suction line - Question from Rockfun
By Brian_UK in forum Air ConditioningReplies: 8Last Post: 14-06-2006, 07:24 PM -
Clear sightglass. Vapor or liquid?
By Sparkplug in forum Trouble ShootingReplies: 5Last Post: 28-02-2006, 09:37 PM -
split AC -outside heat exchanger iced
By Lc_shi in forum Air ConditioningReplies: 2Last Post: 07-02-2006, 12:40 AM -
Liquid refrigerant and bubles in sightglass
By aygul in forum Trouble ShootingReplies: 2Last Post: 30-08-2003, 09:07 PM
