Results 1 to 2 of 2
Thread: Heat Reclaim
07-06-2004, 09:08 AM #1
Heat Reclaim
Do other Fridge Engineers out there have ongoing problems regarding the performance of PARALELL HEAT RECLAIM SYSTEMS?
Any performace data you can provide with real life operational information would be greatly appreciated.
I am interested in the energy effeciency of this so called "free heat"
07-06-2004, 03:41 PM #2
Re: Heat Reclaim
hi tako,
I've installed aheat reclaim system in a dairy in 87. it was a stainless steel 200L tank with 3 refrigerant circuits. supplying hot water for the milking parlour at 40C. no problems for 10 years. then it started leaking inside and was replaced by another one made by ELEKTROGENO gmbh. started leaking after 5 years and the owner didn't want to use them anymore.
it is not cheap and when no problems, it supply's free hot water at 40 to 60C depends on how long the condensing units work.
I would advice to check the rentability against the price of a KW electricity.
there is a new hot water device that works on the principal of conductivity and supply's instant hot water up to 95C.
so far it works fine (only one year at use). owner is pleased but the cost , again is not cheap.
chemi
New Heat Pump Forum
By Argus in forum Heat PumpsReplies: 17Last Post: 10-04-2010, 09:12 AM -
Sporlan Heat Reclaim Valve
By 750 Valve in forum CommercialReplies: 7Last Post: 05-07-2008, 03:20 PM -
Heat Reclaim
By chilled2005 in forum Supermarket RefrigerationReplies: 19Last Post: 05-05-2008, 05:32 PM -
frostles heat pump
By Lc_shi in forum New TechnologiesReplies: 27Last Post: 31-03-2008, 07:53 AM -
R134a <-> liquid heat exchanger design
By DaBit in forum Technical SpeculationsReplies: 19Last Post: 10-05-2002, 08:36 AM
