Thread: Accumulator
27-04-2009, 11:27 AM #1
Accumulator
Hi every body
In a secondary coolant system we have screw type compressors (HSN 7471-75-40P and CSH 8571-140-40P)and wondering if we need accumulator or not .
On the other word , is liquid return to screw compressors a serious problem ?
Thank u for ur attention.
27-04-2009, 12:38 PM #2
Re: Accumulator
That is not the right question.
The question you shall ask to yourself is: "did I make all efforts to avoid liquid floodback?". If not or unsure, install an accumulator.
27-04-2009, 02:36 PM #3
Re: Accumulator
We r gonne install but not sure if it is possible to omit it or not ?
Is liquid flood back a threat to screw type compressors or these types can bear in case of a little amount of flood back
27-04-2009, 04:06 PM #4
Re: Accumulator
Floodback cannot be considered at design time. Not an option.
Then, the compressor may bear it or not, it doesn't matter.
27-04-2009, 05:06 PM #5
Re: Accumulator
I would tend to go for the safest approach and install a accumulator.
27-04-2009, 07:07 PM #6
Re: Accumulator
by the way, liquid flood back is hazardus for EVERY type of compressor. the scroll can take and cope better whit flood back,all the others crash and dye.
ice
29-04-2009, 04:43 PM #7
Re: Accumulator
I think it depends on ur cycle and exp.v type, but Im also not sure about necessity of liquid-return protection for screw compressor. if anyone has such exprience I`ll be appriciated to get advises.
S.P
AWHP design - suction accumulator
By desA in forum Heat PumpsReplies: 9Last Post: 05-09-2010, 07:53 AM -
Does Accumulator really prevent liquid return to compressor?
By dsltung in forum Trouble ShootingReplies: 8Last Post: 08-03-2009, 03:12 PM -
Thermo KIng CB Max suction accumulator tank cleanning
By coldkeeper1 in forum TransportReplies: 5Last Post: 02-05-2008, 05:40 AM -
suction accumulator control
By samiam in forum FundamentalsReplies: 6Last Post: 22-06-2007, 05:49 PM -
accumulator
By mohamed khamis in forum FundamentalsReplies: 13Last Post: 12-05-2006, 10:00 PM
