Thread: head pressure control
26-04-2009, 06:55 PM #1
hi guys, Our air cooled condenser has 5no 2kw fans controlled via a step controller and pressure switch. As an upgrade we were thinking of installing a vfd and presure tranducer to control the head pressure. Is it wise to have 5 seperate vfd or just 1?regards Wing
26-04-2009, 07:34 PM #2
Re: head pressure control
Yes you will need 5 VFD's
But before you do it, consult the experts in fans:
http://www.ziehl-abegg.com/en/index.html
29-04-2009, 02:11 PM #3
i would suggest one speed drive (danfoss akd type)or similar using a tranducer(sized accordingly).... then a change over relay controlled by a hp switch which will bring in your old step controller as a back up just in case ..... i use this system in all my packs .... great control with peace of mind...
PT chart for different elevations
By dkalasz in forum Tools and CalculatorsReplies: 84Last Post: 20-07-2008, 05:09 PM -
Low head pressure Versus Heat reclaim.
By taz24 in forum Supermarket RefrigerationReplies: 17Last Post: 20-03-2008, 12:47 PM -
Benji
By benji in forum Trouble ShootingReplies: 29Last Post: 30-01-2008, 02:25 PM -
Control scenario
By Mike Hopkins in forum Technical DiscussionsReplies: 5Last Post: 14-09-2007, 11:25 AM -
Cycling on head pressure
By Geofridgee in forum Air ConditioningReplies: 4Last Post: 20-06-2006, 05:36 PM
