    Dec 2008
    Portugal
    41
    1,039
    12
    Cascade cooler for r744 (co2)
    What's your feedback, based in the experience of working with cascade refrigerant plants with R717 (high temperature) / R744 (low temperature), in using semi-welded plate R744 condenser of ALFA LAVAL M10 and MK15 or with another brands?
    Dec 2008
    Portugal
    41
    1,039
    12
    Re: Cascade cooler for r744 (co2)
    I'll try again .
    Quote Originally Posted by Sandro Baptista View Post
    Jan 2006
    Valrico, Florida
    517
    12
    I'll try again .
    I am thinking that no one has anything to comment on this, in the States there are very few of these in use for cold storage warehouses, USCS (United States Cold Storage) is the only company that I know of that uses this type of system.
    wholesaler nh3's Avatar
    wholesaler nh3 Guest
    Hi In sweden we have a ammonia /co2
    system with alfanova highpressure
    exchanger and it works fine
    forget the m10 you must have alfanovas.
    Aug 2007
    Moscow
    38
    4
    +1
    Forget M10
    Use AlfaRex, Plate and Shell or Shell and Tube
    Nov 2006
    Nantes
    5
    Hello !
    Use the Brand "vahterus" !
    They have shell and plates heat exchangers for CO2 applicaions : pump / flood etc ... with very high design presure if you Want. In france, we must design a heat exhanger at 50 bars if we use hot gaz for defrosting and the test presure must be at 100 bars. Just "vatherus" can do that. and the cost is very below a Alfa laval model.
    Best regards
    I can give to you my contact for "Vatherus" if you whant !!
  1. "Home made" ice water based packed food cooler
    By SteinarN in forum Fundamentals
    Last Post: 26-03-2009, 07:54 PM
  2. Ultra compact water cooler for Tig Welding?
    By bjamesw in forum Fundamentals
    Last Post: 28-12-2008, 03:04 PM
  3. Cornelius "Pepsi" cooler power?
    By ibrubeer in forum Fundamentals
    Last Post: 01-09-2008, 10:51 PM
  4. NH3 thermosiphon oil cooler
    By cygbob in forum NH3
    Last Post: 22-06-2008, 05:12 PM
  5. TXV hunting in a walkin cooler
    By dkemper in forum Trouble Shooting
    Last Post: 15-11-2007, 03:14 PM
