Thread: Un known screw compressor
24-04-2009, 08:07 PM #1
HI guys i have been asked to look at a screw compressor but i have nt got a clue to what it is, may be some one can identify it and let me know,its badged up as a york and also its terminal plate is same as the york j body recipes and weighs around 600kg
25-04-2009, 09:09 AM #2
Re: Un known screw compressor
Pic is very small it is possibly a frick screw comp but not sure, more pics with close ups could help to identify it.
25-04-2009, 11:22 AM #3
He GHAZ!
it is for sure a YORK compressor. Model XHS (semihermetic screw with internal gearbox). I have overhauled a few of these types and I can tell you that they are not the easiest on the market. If you need some advice let me know.
The Screwdoctor
28-04-2009, 11:35 AM #4
Hi GHAZ
I would say its a Frick XJF 120 or 151.It could also be the same compressor using York's nomenclature as Screwdoctor has mentioned.
28-04-2009, 10:36 PM #5
Hi, itn is york XHS-120
15-11-2010, 09:01 AM #6
15-11-2010, 06:57 PM #7
Hello Pete d,
send me an e-mail with your questions and the technical info you need.
The Screwdoctor
Oil Lifting Problem in NH3 screw compressor
By SURESH YADAV in forum Refrigeration - The StoriesReplies: 20Last Post: 16-10-2009, 01:34 AM -
Noisey screw compressor on Hitatch samurai chiller
By mr slim in forum Air ConditioningReplies: 1Last Post: 22-10-2008, 10:47 PM -
parallel operation of screw compressor and piston type
By cheikh ahmed in forum FundamentalsReplies: 9Last Post: 26-08-2008, 08:34 AM -
Autoloading slide valve for Screw compressor
By screw_geek in forum Industrial CompressorsReplies: 32Last Post: 04-04-2008, 03:47 AM -
refrigerant oil for screw compressor
By nabil in forum New TechnologiesReplies: 6Last Post: 30-05-2007, 08:49 PM
