    Apr 2009
    California
    8
    Question Wet Bulb Measurements
    have a couple of questions for all of you smart technicians! I appreciate any information you can provide.
    How many technicians are measuring Wet Bulb temperatures? (out of 100 techs, how many measure wet bulb?)
    Where do technicians take these measurements? Inside the building? At the return Grille? In the return duct work? in the return plenum?
    What do you use to measure the wet bulb temperature?
    What do you use the wet bulb measurements for?
    11,025
    Re: Wet Bulb Measurements
    Is this a survey for someone or are you trying to find out how to do it ?
    Apr 2009
    California
    8
    I work at Fieldpiece so I am very familiar with how to do this.
    I meant this as a survey to see what actual HVAC technicians are doing so I can better understand how to help them to do their job easier and faster!
    Jun 2006
    British West Indies
    543
    i tried your wet bulb thermocople with the wick, poor results, I was dissapointed in it and I vote it a POS. Had better results with wet toilet paper on a standard thermocouple then the wick deal you guys sell.
    I have had good results with accurate temperature probes with a snug fitting wick.
    i like your pipe clamp one though for superheat and subcooling
    i do not have much faith in the digital probes that are based on RH and spit out a wet bulb, pretty finicky when the device is in the budget range of the average tech
    Take the V out of HVAC and you are left with a HAC job
    Apr 2009
    California
    8
    Quote Originally Posted by Abby Normal View Post
    I appreciate the feedback. The wet bulb T-couples work best when there is air passing across them. I haven't heard this complaint before so I will check into this.
    Glad you like the pipe clamp. We have a few instruments that make superheat and subcooling a cynch as well.
    If you ever have any other questions or comments, just let me know!
    Nov 2006
    708
    Can`t beat the latest Testo pipe clamps , very sturdy fast and accurate, but at £100.00 each they are not cheap
    Jun 2006
    British West Indies
    543
    Quote Originally Posted by TravisAult View Post
    they read high, inserted into a duct, I do not see how the wick can sufficiently cool the thermocouple
    before I wet the wick, I checked it against another thermocouple, it read pretty close to what the dry wick was reading.
    I tried a wet bulb reading in a duct with the wet bulb probe, tried it against a short ridge probe with a wet sock, several degrees difference.
    put wet toilet paper on the other thermocouple, pretty close to what the shortridge was saying.
    I say the wet bulb thermocouple I ended up with reads a good three degrees high, and I think it is because the wick does not cool the thermocouple adequately.
    This was straight out of the package
  1. Use of Dry/Wet bulb when design a ac system
    By happychan314 in forum Air Conditioning
    Last Post: 13-04-2009, 04:31 PM
  2. How many forum posters does it take to change a light bulb....
    By taz24 in forum Chit Chat & Service Stories
    Last Post: 04-02-2008, 07:05 AM
  3. Benji
    By benji in forum Trouble Shooting
    Last Post: 30-01-2008, 01:25 PM
  4. tev bulb in immersion well?
    By angryk in forum Fundamentals
    Last Post: 20-01-2003, 09:42 PM
  5. Replies: 5
    Last Post: 16-10-2002, 12:38 AM
