Results 1 to 9 of 9
Thread: Frick 9x9 help
    Apr 2009
    Colorado
    31
    Frick 9x9 help
    Yes, it still runs. Level control on the evap got stuck. Slugged liquid into crankcase of compressor. How can I get it out ? Thanks ,Mojjee
    Somerset
    69
    4,698
    Re: Frick 9x9 help
    Put a heat source radiating onto the crankcase.
    And let the liquid boil off slowly,
    Once it is all gone and the sump temp is back to normal...
    Away you go!
    Jul 2007
    Czech
    61
    373
    Re: Frick 9x9 help
    Hi, certainly grateful compressor
    Attached Files Attached Files
    Aug 2005
    5,302
    Re: Frick 9x9 help
    Away you go!
    What he said! With one additional comment.
    Make sure the compressor does not start until the sump temperature is warm enough.
    Apr 2009
    Colorado
    31
    Re: Frick 9x9 help
    Thanks Guys, used 2 salamanders on it. It took a while but it worked fine.
    Somerset
    69
    4,698
    Re: Frick 9x9 help
    Yo!
    Thanks Iceman.
    As they say over here " I forgot to state the Bleeding Obvious!"
    For those that might not understand.
    A sump full of low pressure liquid could be holding the compressor off on L.P.
    Therefore during the course of reheating the L.P. and temp would rise above set-point.
    Where the comp could re-start.
    Mojee.
    What's a salamander?
    |Grizzly
    Aug 2005
    5,302
    Re: Frick 9x9 help
    Whats a salamander?
    http://en.wikipedia.org/wiki/File:Me...chrischan.jpeg
    Just kidding... The link below describes the variety of salamander being used.
    http://www.masterheaters.com/kero/
    PS. The first link would provide very little heat to help with the original problem.
    Somerset
    69
    4,698
    Re: Frick 9x9 help
    Thanks for the explanation Ice.
    Can't remember what they are called over here?
    I think it may be Space Heaters?
    Ideal for the job though whatever they are called.
    Cheers Grizzly
    Apr 2009
    Colorado
    31
    Re: Frick 9x9 help
    Big propane fired heater usually used on construction sites during winter.
  1. Frick screw paper
    By RANGER1 in forum Industrial Compressors
    Last Post: 08-03-2009, 08:45 PM
  2. Frick compressor RXF 101-H
    By PaulZ in forum Industrial Compressors
    Last Post: 19-02-2009, 02:29 AM
  3. Replies: 12
    Last Post: 16-06-2008, 10:06 AM
  4. Frick Quantum Panel
    By LEE40 in forum Trouble Shooting
    Last Post: 27-03-2008, 05:24 PM
  5. old frick system monitor
    By rasgrant in forum NH3
    Last Post: 17-01-2007, 06:15 PM
