Results 1 to 8 of 8
Thread: hbp compressor
    mazawi's Avatar
    mazawi Guest
    hbp compressor
    hi
    i just fitted mbp 404a compressor for a small freezer room. the temp is not dropping below -10 . what shall i do?
    Split Croatia
    57
    6,151
    36
    Re: hbp compressor
    You should start with giving more information's.
    If you don't know what information's you (and we) need, then you should call someone who knows.
    Start with some description of situation and pressures and temperatures.
    Keyboard will not bite you.
    Oct 2003
    5,630
    34
    Re: hbp compressor
    I think you used the wrong gas, try R507c instead.
    11,025
    Re: hbp compressor
    Quote Originally Posted by mazawi View Post
    hi
    Investigate further or call a refrigeration technician.
    Apr 2009
    earth
    Re: hbp compressor
    how small is the freezer room? and horsepower of the compressor?
    Oct 2003
    5,630
    34
    Re: hbp compressor
    I should add gas till temperature drops.
    Man, wat smijten ze hier nu weeral binnen, de eerste beste foefelaar.
    Aug 2008
    Auckland
    55
    259
    21
    Re: hbp compressor
    These type of posts do tend to iritate me somewhat.......
    May 2008
    66
    802
    Re: hbp compressor
    Peter, ik heb het poortje niet open gelaten hoor......LOL.
    ice
  1. LG heat pump problem
    By back2space in forum Heat Pumps
    Last Post: 01-02-2009, 11:23 PM
  2. compressor / electrical problem
    By Northdude in forum Commercial
    Last Post: 17-01-2009, 10:24 AM
  3. Compressor loading, cooling, and range of operation.
  4. SL/SB-400 Pump Down Procedures
    By absolute-zero in forum Transport
    Last Post: 29-01-2008, 09:27 PM
  5. Compressor pumping efficiency
    Last Post: 25-02-2004, 10:50 PM
