Results 1 to 42 of 42
Threaded View
22-04-2009, 04:33 PM #1
Am I doing the right thing before I give the go ahead:
Hello guys, just looking for a little support on this matter. As you know my system is being replaced and I have been given two different quotes, Multi Split or separate systems. Am I doing the right thing going for the separate systems? I know I can use the auto change over function and have diff rooms in heating/cooling on separates if required.
Equipment suggestions as follows; This is for Mitsi M Series: Separates works out cheaper than Multi.
Separate Splits:
2 X SUZ-KA35VA (OUTDOOR UNITS 3.5KW)
2 X MFZ-KA35VA (INDOOR FLOOR MOUNTED UNITS 3.5KW)
1 X MUZ-FD35VAH (OUTDOOR UNIT 3.5KW)
1 X MSZ-FD35VA (HIGH COP INVERTER WALL MOUNTED UNIT 3.5KW)
Multi Split:
1 X MXZ-4A80VA (OUTDOOR UNIT 8KW)
2 X MFZ-KA35VA (FLOOR MOUNTED UNITS 3.5KW)
1 X MSZ-FD35VA (DELUXE WALL MOUNTED UNIT 3.5KW)
Worried about Maintenance costs also, for instance if compressors go after the warranty on two systems then I assume its more expensive than just fixing a multisplit unit
Been given running specs so I can see just how much each system should use and what the multi would use: Seems cheaper to run one split system rather than the multi if I only want one indoor unit operating. However uses more wattage if all three are running flat out wheareas multi comes in less if all 3 are running.
Separate splits: Can ramp down more thus producing even less capacity if need be.
Capacity - Cooling (min. - max.): 0.9 - 3.9 kW
Capacity - Heating (min. - max.): 0.9 - 6.2 kW
Power input - Cooling (min. - max.): 0.19 - 1.25 kW
Power input - Heating : 0.19 - 2.24 kW
Multisplit: Specs for 1,2 & 3 unit operation: To have one unit operating uses more than if one was operating.
1. Capacity - Cooling (min. - max.): 3.5 (1.5 - 4.3)
Capacity - Heating (min. - max.): 4.0 (1.2 - 4.8)
Power input - Cooling (min. - max.): 1.030 (0.400 - 1.290)
Power input - Heating : 1.210 (0.330 - 1.570)
2. Capacity - Cooling (min. - max.): 7.0 (2.0 - 7.1)
Capacity - Heating (min. - max.): 8.0 (1.8 - 9.8)
Power input - Cooling (min. - max.): (0.540 - 2.550)
Power input - Heating : 2.370 (0.480 - 3.230)
3. Capacity - Cooling (min. - max.): 7.95 (2.9 - 9.0)
Capacity - Heating (min. - max.): 9.4 (2.6 - 11.6)
Power input - Cooling (min. - max.): 2.280 (0.720 - 2.910)
Power input - Heating : 2.170 (0.530 - 3.380)
If you dont mind, what is your opinions on all of the above. Aesthetics are not a problem etc. I am spending a lot more this time than the LG and want to make sure the overall solution is perfect.
Installer reckons multisplit but this comes out at £450 more than separate splits, he says over the long run it will work out cheaper for me???? Confused.com now!Last edited by back2space; 22-04-2009 at 04:43 PM.
Such thing as a rental Dehumidifier?
By Sub-zero in forum CommercialReplies: 6Last Post: 06-08-2009, 11:15 PM -
Can you give me a help?-Books
By haojiexp in forum TransportReplies: 1Last Post: 17-08-2008, 09:41 AM -
Give it a thought for sure...
By Josip in forum Chit Chat & Service StoriesReplies: 6Last Post: 15-08-2008, 07:25 PM -
Welcome thing!
By WebRam in forum New to REReplies: 0Last Post: 19-10-2005, 11:20 AM -
The darndest thing
By Coolie in forum Trouble ShootingReplies: 9Last Post: 29-11-2004, 05:49 PM
