Results 1 to 8 of 8
Thread: Head Pressure control valve
22-04-2009, 09:04 AM #1
Guys,
Please recommend pressure control valve brand. What i know is Sporland , Danfoss and Alco is famous in market but i looking for other brand else for alternative brands ,
or you can recommend any local brand with good quality. Thanks.
Function for this valve : maintain proper air-cooled condenser pressures during periods of low ambient conditions
22-04-2009, 11:42 AM #2
22-04-2009, 11:13 PM #3
Re: Head Pressure control valve
If you are looking for cheap then search the Chinese websites.
As a 'Purchaser' you will find that Google can help in your quest.Brian - Newton Abbot, Devon, UK
21-10-2009, 09:30 AM #4
If you do not wish to purchase head pr controller , install a pr switch & modulate head pressure . It will have howver swings in pr values .
Besides, only head pr controller is not the solution , you will need a proper size of receiver to handle low and high loads without starving tex valve. An alternative is to modulate speed of cond fans if air-cooled . Or have water flow regulating valve in case if you use water cooled condenser .
21-10-2009, 09:42 AM #5
Penn is ok .
21-10-2009, 11:25 PM #6
He really doesn't care folks, OP was April 2009 and he hasn't been back since.
09-12-2009, 02:36 AM #7
Parker A8 or A9
27-04-2010, 11:24 AM #8
Jip Brian...
opens on rise of outlet
By subzero*psia in forum CommercialReplies: 24Last Post: 01-03-2008, 10:46 AM -
Liquid Overfeed Systems
By US Iceman in forum NH3Replies: 151Last Post: 08-03-2007, 05:34 AM -
Screw compressor system losing oil differential pressure
By orm in forum Trouble ShootingReplies: 27Last Post: 27-10-2006, 03:19 AM -
Short Cycling blues & low pressure control switch
By mccoolair@yahoo in forum Supermarket RefrigerationReplies: 14Last Post: 09-04-2006, 09:28 PM
