    Lloyd Dias's Avatar
    Lloyd Dias Guest
    Measurement of flow rate
    Could someone help me, I want to know how to calculate the flow rate of refrigerant inside an air conditioner. Is there a device or formula i can use.
    Apr 2009
    Johor
    5
    Re: Measurement of flow rate
    Quote Originally Posted by Lloyd Dias View Post
    Anemometer, usually the reading in m/s (air velocity), then you need to know the face area to calculate the air volume.
    Split Croatia
    57
    6,151
    36
    If you know displacement of compressor and discharge (or suction) pressure, you could calculate flow from refrigerant properties (density at certain pressure).
    Also, you could use coolpack software for such calculations.
    http://www.et.web.mek.dtu.dk/Coolpack/UK/download.html
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by robgfreeze View Post
    Please, read question one more time.
    west midlands
    98
    Hi Lioyd,
    If you wish the Mass flow rate of your refrigerant you could simply divide your capacity (kw) by your Refrigeration Effect. This might be a little easier than working out your displacement and dividing by the specific volume described earlier by Nike 123. it would depend of course if you are happy with your Mollier charts.
    Sparrow
    Always easy on the eye.
    moideen's Avatar
    moideen is offline Veteran Poster I am starting to push the Mods: of RE
    Apr 2008
    u.a.e
    49
    412
    23
    Quote Originally Posted by sparrow View Post
    Hi Lioyd,
    Sparrow
    could you explain it with examples...
    thanking
    moideen-dubai
    west midlands
    98
    Moideen, hi actually it should be recorded on a phychometric chart, not as I had written above. I am doing many things at the moment with mollier charts and can confuse even myself at times.
    Sparrow
  1. How to calculate the Flow rate of air blower(centrifugal type)
    By nadeemnisa in forum Technical Speculations
    Last Post: 26-06-2009, 07:53 AM
  2. Capillary Tube Characteristics
    By Chef in forum Fundamentals
    Last Post: 10-03-2009, 01:03 PM
  3. Mass Flow Rate with Big Condenser
    By jwasir in forum Fundamentals
    Last Post: 27-07-2008, 10:31 PM
  4. high volume flow rate
    By cakabo28 in forum Technical Discussions
    Last Post: 04-10-2007, 03:41 AM
  5. Shell/Tube flow rate?
    By reggie in forum Fundamentals
    Last Post: 17-11-2002, 05:41 PM
