Thread: reheat coil
21-04-2009, 02:16 AM #1
reheat coil
can anyone give me an idea regarding reheat coil? coz i need to used it in a cold room for seeds.
thank you
21-04-2009, 05:03 AM #2
22-04-2009, 01:13 PM #3
Re: reheat coil
determine the dewpoint you need to maintain in that room.
cool the air down below that dewpoint.
on a rise in RH, heat the supply air temperature up to the room temperature you need to maintain.
disengage reheat if room temperature starts to rise, re-engage the reheat if RH is still high after the cooling call ends.
if you still cannot control humidity, drop the supply air temperature down a couple degrees to get a lower supply dewpoint.Take the V out of HVAC and you are left with a HAC job
About 2 stage coil
By cstyx in forum Technical DiscussionsReplies: 3Last Post: 09-04-2009, 08:26 PM -
Efficiency of compressor assisted HRV
By montreal in forum Heat PumpsReplies: 46Last Post: 27-08-2007, 08:51 PM -
Dont be shy, advice needed.
By Sledge in forum Air ConditioningReplies: 9Last Post: 27-06-2007, 03:09 PM -
Burst Coil
By frank in forum Air ConditioningReplies: 13Last Post: 20-02-2005, 06:28 PM -
Article in ACH&R News
By Gary in forum FundamentalsReplies: 8Last Post: 20-05-2003, 12:27 AM
