    Oct 2007
    shepton mallet, somerset, england
    59
    Rotocold shaft-seal
    Hello
    Does anyone know where I can get replacement parts, mainly shaft seals for a Rotocold R81 rotary compressor.
    I have searched the net and have come up with Rotocold ltd. in Bolton, but I cannot get through to them, I suspect they no longer exist or have been taken over?
    Any help would be greatly appreciated.
    cheers
    Shaun
    Mar 2008
    United Kingdom
    Re: Rotocold shaft-seal
    This is the closest thing I could find but looking at the contact info they are not in the UK. They may know of a uk supplier if you e-mail them. I am pretty sure rotocold went bust some time ago. I haven't worked on one of them since the late 80's.
    http://www.jotek-eng.com/modelcorrelations.htm
    Maybe some of the guys on here could have more luck, I have also found reference to them as Frick Blu-Cold (previously rotocold). Good Luck.
    Somerset
    69
    4,697
    Quote Originally Posted by borley View Post
    Hello
    cheers
    Shaun
    Hi Shaun.
    I don't like posting links to specific companies as it is unfair to all the users that have an allegiance.
    But as your case is so specific.
    May i suggest you try Seals and Mounts at Wellington Somerset (01823 660033)
    I have not used them myself, but I have several customers that do and they seem happy.
    I know they refurbish Shaft Seals and I am certain that they Will be able to identify the seal and help?
    Also as they are so close you could if you choose pop in and seek their advise!
    The guys i use are up in Nottingham so as a last resort if you are still stuck.
    Let me know and I will pass on their details.
    Compressors may differ but there are not that many seal manufacturers.
    So identification should not be that bad!
    Good Luck Grizzly.
    Oct 2007
    59
    Thanks for all the help guys. Cheers
    Shaun
  1. Help needed in Venezuela.
    By El Tel in forum Industrial
    Last Post: 15-03-2010, 10:54 PM
  2. Frick shaft seal leaking
    By Ian B in forum Industrial Compressors
    Last Post: 27-01-2009, 10:31 PM
  3. Need info on the shaft seal system for scotsman
    By The MG Pony in forum Commercial
    Last Post: 17-03-2008, 02:02 AM
  4. X430 Ls Seal
    By TECH0091 in forum Fundamentals
    Last Post: 17-05-2007, 09:09 PM
  5. Bock AM5 compressor's shaft seal failiure
    By Gareth in forum Trouble Shooting
    Last Post: 05-04-2004, 09:12 PM
