19-04-2009, 09:37 PM #1
Mitsubishi Heavy Industries head unit FDTJ90SHKXE2 nosiy operation
Hi, Annoying 50HZ motor buzz where the air movement fan is acting as a mechanical amplifier. I think this is because the rubber bush between the fan and the motor shaft is knackered (gone hard). Is it possible to replace this bush alone or do I need to bite the bullet and order new fans (multiple head units with fault)? Tried changing the motor but this does not solve. Putting thin sheets of rubber samwidged between washer helps to quieten things up allot but repair is only good for 5 months or so.
Suggestions please,
Andrew.
21-04-2009, 01:49 PM #2
Re: Mitsubishi Heavy Industries head unit FDTJ90SHKXE2 nosiy operation
If in doubt read the instructions. If still in doubt follow them.
Mitsubishi Heavy Industries FDC2501 tech advice required
By aeaves in forum Air ConditioningReplies: 1Last Post: 20-04-2009, 08:44 AM -
Problem with Mitsubishi Heavy Indusry Unit blowing 3 amp fuse
By kelvin01 in forum Air ConditioningReplies: 3Last Post: 04-03-2007, 07:03 PM -
Troubleshooting Mitsubishi Heavy VRV System
By Cofreth in forum Trouble ShootingReplies: 2Last Post: 29-08-2006, 05:41 PM -
Mitsubishi Heavy Industries HELP
By Bakerbj in forum Air ConditioningReplies: 10Last Post: 26-07-2006, 03:18 PM -
MV600 head pressure trip (ghost)
By andre_fridge in forum Technical DiscussionsReplies: 9Last Post: 28-01-2006, 02:16 PM
