Results 1 to 22 of 22
    Mar 2006
    Lancashire
    1,859
    28
    Insulation resistance tester/multimeter
    As the title says im looking for a good Insulation resistance tester/multimeter. I have been looking at the Fluke 1587 but it's out of my price range.
    Can anyone reccomend a less expensive one?
    Marc
    Nov 2006
    708
    23
    Re: Insulation resistance tester/multimeter
    Alphatec do some reasonably priced equipment also kew which is similar to robin meters both available from CEF
    Split Croatia
    57
    6,151
    36
    Mar 2006
    Lancashire
    1,859
    28
    I'll go into CEF today and have a look.
    Nike; can't find any info on that model, where can i find a stockist?
    Marc
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by marc5180 View Post
    http://www.uni-trend.com/portfolio.html
    For stockist, try Google "uni trend UK" or contact them by e-mail.
    Mar 2006
    Lancashire
    1,859
    28
    Is this the same one Nike?
    http://www.radio-factory.com/unit-ut...058b4c9fce0393
    Does it work by sending voltage down the winding like a megger?
    Marc
    Sep 2003
    ISRAEL
    72
    4,248
    look for Greenlee on ebay,
    TES-1600 also very good, I have one for years now,
    Don't be afraid to buy second hand, good tools last for almost ever.
    Mar 2006
    Lancashire
    1,859
    28
    Thanks Chemi.
    Are insulation resistance meters the same as meggers?
    Marc
    Sep 2003
    ISRAEL
    72
    4,248
    Yes. Megger is only a brand name.
    www.megger.com
    Nov 2006
    708
    23
    Just clear you query a megger is called so because it measures mega ohms hence most people refer to insulation resistance testers that measure these large resistances as meggers, its a bit like hoovers and stanley knives etc
    Mar 2006
    Lancashire
    1,859
    28
    So i take it these insulation resistors can generate voltage to send down the winding.
    The first pic is of a megger that i have seen before but the 2nd picture just looks like an everyday voltmeter. Do they both do the same job?
    Marc
    Auckland
    74
    3,357
    37
    Hi Marc
    I use a FluKe 73 as a general multi-meter and for initial meg testing, but several years ago invested in a AVO electronic, with multi-output voltages. Totally reliable and accurate, regularly check it against a couple of resistors. The out put voltages can be dangerous if your hands get in the way.
    Generally if you want accurate measurements and information, you need to spend the money for quality.
    Apr 2009
    California
    8
    Just for everyone's information:
    Here is an example of a meter that can be used for this application.
    SMG5 Megohm meter, small, low cost meter for checking compressor insulation.
    The SMG5 provides a 1000V voltage source, monitors current and displays the resistance between the test points. Maximum current output is <1mA. It can be used to determine the condition of insulation from winding to ground in a motor, compressor or transformer.
    Disconnect the windings and measure the resistance between the windings and ground through the insulation. Determine what a good reading is by comparing your reading to values supplied by the manufacturer of the equipment.
    Noticing decreasing insulation resistance levels can forecast problems preventing catastrophic failure.
    • Predict compressor failure.
    • 1000VDC stresses insulation to measure up to 2000Mohms.
    • Backlight LCD Display.
    • Auto off to extend battery life.
    • Supplied with case, alligator clips and leads with removable tips
    Split Croatia
    57
    6,151
    36
    Yes, it is!
    That is real megaohm tester/multimeter as you asked!
    You could select test voltages.
    Check specifications at top.
    I have their digital multimeter and it is very good quality.
    Mar 2006
    Lancashire
    1,859
    28
    How does a 9v battery generate 500v though?
    Marc
    Split Croatia
    57
    6,151
    36
    Inverter!
    Diode-capacitor bank!
    http://www.electronicsforu.com/elect...ltage%20Source
    Mar 2005
    u.a.e
    68
    169
    Hi Marc
    Hioki from Japan is a very good instrument, if you can get in your market, these instruments are cheaper then other brands, but quality is same.
    Nov 2006
    708
    23
    If all your gonna use the tester for is the odd motor etc. then the one suggested by nike would probably do the job. If your gonna use it for electrical instalation testing then a more substantial unit would give you far better battery life. Its horses for courses if you like
  19. #19
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by Quality View Post
    He is not electrical installations tester guy, he is refrigeration service engineer, and measuring of insulation is something he will do few times a year.
    This type of equipment is perfectly suited for that purpose
  20. #20
    Nov 2006
    708
    23
    just depends if he want a mickey mouse meter or not
  21. #21
    Split Croatia
    57
    6,151
    36
    What makes you think that that meter is "mickey mouse" meter.
    Please, give us specifications of non-mickey mouse meter.
  22. #22
    Nov 2006
    708
    23
    I was trying to offer my advice based on my experience , Hence as I suggested the battery life in your average "smaller" meter is very limited
  1. Insulation for Cold Room
    By tjk2007 in forum Fundamentals
    Last Post: 19-03-2010, 02:54 AM
  2. Help needed sourcing insulation for a Display Case
    By jimbo22 in forum Technical Speculations
    Last Post: 03-11-2008, 09:30 AM
  3. PTC & NTC Probes.
    By Testech in forum Electrical
    Last Post: 06-06-2008, 10:01 PM
  4. Emmisivity as insulation thickness determinant ?
    By sharshal in forum Technical Speculations
    Last Post: 23-10-2006, 02:26 AM
  5. Suspended Floor Insulation
    By Colin Kaminski in forum Commercial
    Last Post: 08-02-2006, 06:10 PM
