Results 1 to 10 of 10
Thread: Dorin K40CC
    Feb 2007
    Portugal
    5
    Dorin K40CC
    I have a problem with a compressor Dorin K40CC that is the following one: He works very well but after the defrosting it enters in vacuum (-10psi) and delay more or less fifteen minutes to normalize… why?
    Split Croatia
    57
    6,151
    36
    Re: Dorin K40CC
    What makes you think that problem is in the compressor?
    Sep 2003
    ISRAEL
    72
    4,248
    Re: Dorin K40CC
    Of course Nike, the compressor pulls the vacuum!!
    xexito, check your controlls.
    Feb 2007
    Portugal
    5
    Re: Dorin K40CC
    Quote Originally Posted by xexito View Post
    The problem is realy the compressor, because this same compressor was exchanged for a new and the problem no longer exists ...
    Split Croatia
    57
    6,151
    36
    Re: Dorin K40CC
    Very strange and impossible to believe for me without further clarifications.
    If compressor pulls vacuum that indicate that compressor doing his task (pumping) and that somewhere before pressure measuring point (where vacuum is observed), is some obstruction to refrigerant flow, or there is not enough heat at evaporator.
    So question is: exactly where in circuit did you measured vacuum?
    Next question would be: did You changed refrigerant with new fresh one, when you changed compressor, or did you recovered old refrigerant using new filter-dryer (as should be the trade practice) in line at suction of recovery gear, or you simply pumped system refrigerant in to receiver?
    During compressor replacement, did you changed existing filter dryer in system with new one, as should be trade practice?
    Or, could you describe exactly, step by step, everything you done during change of compressor?
    495
    21
    Re: Dorin K40CC
    Totally agree with nike123 if the compressor is pulliing a vaccum then its pumping and pulling fine and the fault is some where else in the system.
    Somerset
    69
    4,698
    Re: Dorin K40CC
    xexito.
    Hi I must admit your question is strange, because a Dorrin Compressor designated CC is for Air-conditioning applications?
    Yet you mention a issue after defrost?
    So is the equipment correctly sized for the application?
    If it is then my instinct tells me that several things could of occurred prior to the exchange.
    Did the thermostat or any solenoid valves just happen to get changed at the same time?
    I would be looking for why the refrigerant supply to the evap and therefore controlling Suction pressure.
    Was being restricted for this 15 Min's period?
    I suspect an electrical control issue
    or a faulty defrost termination stat.
    Good luck and please let us know more!
    Split Croatia
    57
    6,151
    36
    Re: Dorin K40CC
    xexito.
    CC mean that it has more powerful engine but compressor is same. Therefore, depending on condensation temperature and refrigerant it could work in range -40°C<Te<10°C while C is Te -5°C max.
    Oct 2003
    5,630
    34
    Re: Dorin K40CC
    Had exactly the same problem Nike and even more then once and the problem was indeed related to the compressor.
    There was so much moisture in the system that the mesh filter inside the service valve (Dorin has the same mesh filter as a DWM/Copeland) completely clogged with ice mixed with oil. The compressor then pulls vacuum a vacuum in its sump but on the service valve, you measure a high evaporating pressure.
    Split Croatia
    57
    6,151
    36
    Re: Dorin K40CC
    So, change of compressor would not solve the problem. New compressor comes with same mesh filter and if refrigerant and filter dryer is not changed, same problem will be occurring again.
    Therefore, that is not compressor problem.
  1. Copeland select 6
    By Copman in forum Tools and Calculators
    Last Post: 27-05-2010, 09:01 PM
  2. Require Dorin Info Please
    By dsp in forum Commercial
    Last Post: 10-10-2008, 10:35 AM
  3. Dorin Compressor re-gas amount
    By desserts in forum Technical Speculations
    Last Post: 25-09-2008, 11:30 AM
  4. Dorin Semi hermetic Compressor
    By Samarjit Sen in forum Industrial Compressors
    Last Post: 02-07-2007, 04:06 PM
  5. Dorin Compressors
    By wesmax in forum Chit Chat & Service Stories
    Last Post: 24-03-2005, 04:57 AM
