Thread: Grasso rc219
    495
    21
    Grasso rc219
    Hello guys i,ve rebuilt the compressor and its almost same as grasso rc9 except for one roller bearing in the con rod small end and different pipe work pipe work externaly. what i need is how the machine is piped up and how it operates ,any info would be very grateful,thank you
    Somerset
    69
    4,698
    Re: Grasso rc219
    Gaz.
    I will send you some info!
    The 2 is LP and the 1 is HP.
    The HP cylinder has the roller bearing in the conrod (little end) if I remember correctly. And no spring to return the piston within the Suction loading / unloading assembly.
    The difference is the discharge of the 2 LP cylinders discharge ports pipe into the suction port of the HP cylinder.
    Sometimes these "intermediate stage" lines have liquid injection.
    But I don't think from memory it's relevant on a 3 cylinder machine?
    Anyways have a look at what I forward.
    Steve.
    Jul 2007
    Czech
    61
    373
    Re: Grasso rc219
    Ghaz Hi, Check your mail
    495
    21
    Re: Grasso rc219
    Thankyou grizzly and josef for your info and i can know test run the compressor, thankyou once again
  1. Grasso Single Screw Compressor
    By Sturt in forum History of Refrigeration
    Last Post: 24-02-2010, 09:09 AM
  2. The new Grasso V series reciprocating compressor
    By Sturt in forum New Technologies
    Last Post: 17-11-2009, 09:37 PM
  3. Grasso oil pump
    By geoffg in forum Commercial
    Last Post: 08-08-2009, 07:55 AM
  4. Grasso spares
    By Slush Puppy in forum Industrial Compressors
    Last Post: 23-01-2009, 05:44 PM
  5. KAB (Grasso) drawing
    By Gerben in forum Industrial Compressors
    Last Post: 19-01-2008, 01:27 PM
