Results 1 to 2 of 2
    Oct 2007
    Australia
    40
    13
    Chilled water make up tank
    Can anyone tell me what level a make up water tank should top itself up to? I've done very little on chilled water air con systems. It's currently set up to top itself up to about 10%, but the building sparky keeps wanting to set it to 35 or 50%.
    11,192
    Re: Chilled water make up tank
    I am a bit confused as the why an electrician is telling you what the water level should be in a make up tank.
    The level should be whatever is required to ensure that no air is drawn into the system on initial pump start up unless the system connection is at the ideal balance point when the level will not change.
  1. Ice Bank Tank for Chilled Water
    By Samarjit Sen in forum Commercial
    Last Post: 31-10-2009, 10:18 AM
  2. Need Help with cold water tank design
    By ac_sheldon in forum Industrial
    Last Post: 22-11-2008, 12:24 AM
  3. Energy saving in Chilled water system
    By psrao in forum Tools and Calculators
    Last Post: 15-01-2008, 07:54 PM
  4. Building a wine cabinet
  5. chilled water storage tank!
    By dchatta in forum Technical Discussions
    Last Post: 24-05-2004, 04:23 PM
