Thread: Hotpoint FFA71 Fridge Freezer
14-04-2009, 07:34 PM #1
Hi all
Any help greatfully accepted.
My fridge freezer keep freezing anything in the bottom salad draw and the temp control dials seem to have no effect. Food further up (higher in the fridge)seems to be ok.
So at the moment were are getting lots of frozen lettuces and cucumbers.
Please help!
15-04-2009, 06:24 AM #2
Re: Hotpoint FFA71 Fridge Freezer
Did you change anything related to loading of your fridge, Also let me know by when you started facing this problem as there is some change which is effecting the air flow may be you are blocking the air path at the top hence most of the cooling is getting trasfered to bottom hence excess cooling at the bottom.
thanks
amit
15-04-2009, 10:10 AM #3
Hi Amit
Thanks for your reply.
The fridge has recently been moved whilst we redecorated - so i think this maybe the cause of the problem..
Apart from this we have not moved anything...
Hotpoint FF200E Fridge Freezer Fault
By fredalfred in forum DomesticReplies: 107Last Post: 29-12-2012, 01:26 PM -
Hotpoint FFA7AP Fridge & Freezer Both Not Working?
By ebiz96 in forum RefrigerantsReplies: 4Last Post: 02-02-2011, 06:08 PM -
Indesit FROST FREE Fridge Freezer - fridge not cold
By pauby in forum DomesticReplies: 26Last Post: 09-03-2009, 11:04 AM -
Hotpoint ffa71 freezer wont go cold
By efergie in forum DomesticReplies: 7Last Post: 03-11-2008, 01:44 PM -
Hotpoint FFA71 Freezer High Temp Light / Fridge is Freezing
By sumnerpa in forum Trouble ShootingReplies: 1Last Post: 19-08-2008, 03:16 PM
