    duggied's Avatar
    duggied Guest
    Hotpoint FF187EG
    Hi everyone new to site, need help on hotpoint FF187EG switched power on, power going to circuit board, nothing working, checked compressor fine, checked capacitor, fine, checked thermister/thermostat, they are ok, checked klixon, this is fine, board doesnt smell or look burnt, looks fine.
    No LED to show unit is on, do anybody know what is going on
    Duggied
    Dec 2008
    UAE
    42
    171
    Re: Hotpoint FF187EG
    There is a possibilty that the unit is under defrost mode, Hence let the unit run for 1 hr and then check that the unit runs normally.
    Amit
    duggied's Avatar
    duggied Guest
    thanks amit i will try this
    duggied's Avatar
    duggied Guest
    Hi, Tried this and it did not work, do you have any other suggestions. Thanks
    Dec 2008
    UAE
    42
    171
    Dear Check for the fuse on the board if it is gone then nothing will work. As you are confirming rest all part are working OK, then check
    1. Main power supply board
    2. Fuse on the PCB card
    thanks
    amit
    lebanon
    130
    hi
    there is 3 sensor in ur fridge one for cabihet second for freezer third forthe defrost termination attached to the pipe in freezer comartiment i suspect the last option
  1. Hotpoint FF200E Fridge Freezer Fault
    By fredalfred in forum Domestic
    Last Post: 29-12-2012, 01:26 PM
  2. Hotpoint fridge not cold anymore.
    By tishybabe in forum Domestic
    Last Post: 01-10-2011, 03:24 PM
  3. Hotpoint Fridge-Freezer Model FFA84X & FFA97G
    By eahmed in forum Domestic
    Last Post: 22-06-2008, 09:00 AM
  4. Hotpoint Mistral Plus
    By Bobby Ewing in forum Domestic
    Last Post: 05-01-2008, 11:35 AM
  5. Hotpoint Mistral Plus playing up. HELP! please
    By AJ52TOY in forum Domestic
    Last Post: 04-05-2007, 09:35 PM
