Results 1 to 9 of 9
    Apr 2009
    US
    31
    5
    Student Project (Cascade Refrigeration System)
    I am working on a project to optimize the evaporating temperatures, superheat and subcooling on a 2 stage cascade refrigeration cycle using R404a and R744 (CO2). I've setup everything in EES but I have a few concerns regarding the solution I'm getting:
    My ltc evap temp is -45C and im testing 10C superheat. When I ran the equations, I got a temperature of 58C at the ltc compressor outlet at almost 4 MPa, which seems a bit high to me, but I really dont know for sure.
    I tried to parametrically plot my COP vs. the htc evap temperature, and the COP just keeps going up without bound. I was expecting to see an inverse parabola, but the COP never decreases.
    If anyone has any suggestions for me please let me know. Thanks!
    David
    Mar 2006
    Merate (LC) - Italy
    47
    2,553
    Re: Student Project (Cascade Refrigeration System)
    I'm not sure what exactly you input in the calculation, but I'm pretty confident that 58C at compressor discharge is quite normal, provided the condensing temperature is subcritical (let's say around 50K discharge superheat)
    Apr 2009
    US
    31
    5
    ok, thats good to know, i wasn't sure.
    But now, my problem is that when I plot the COP vs. the cascade temp for a specific set of design conditions, the COP just increases almost linearly without a limit. Any ideas?
    Mar 2006
    Merate (LC) - Italy
    47
    2,553
    That's also normal. As the evap temperature increases, the COP increases as much, and the reason is the higher mass flow at suction together with a better volumetric efficiency. Please note that the evap temperature in a real case scenario is bound to the physical constraint of the testing setup
    tctarunchauhan's Avatar
    tctarunchauhan Guest
    hey buddy may i have ur analysis on EES..??? if u dont have any prob plz send it to me....i thnk i m working on somewhat similar project so i need ur help
    rockon605's Avatar
    rockon605 Guest
    is there any way to plot property curve (say T-s diagram) for two different fluids on same graph, i.e. overlaying one's property plot over another in 'EES'?
    if anyone knows plz reply.
    actually i need combined T-s diagram for ammonia and ethane on one plot.
    Mar 2009
    KZN, South Africa
    58
    2,212
    14
    Coolpack can assist. It's a free download based on the EES platform.
    pal.of.pinaki's Avatar
    pal.of.pinaki Guest
    Unhappy Re: Student Project (Cascade Refrigeration System)
    Hey guys,
    I am also working on a project based on CO2 cascade refrigeration systems......if anybody can send me the code pertaining to the optimisation of cascade system in terms of intermediate temp.(IT) and overlap temp(DT) I would be highly thankful.
    jonbonraki's Avatar
    jonbonraki Guest
    I am also working on a project based on CO2 cascade refrigeration systems......if anybody can send me the code pertaining to the optimisation of cascade system in terms of temp(DT) .
  1. Replies: 9
    Last Post: 30-11-2009, 10:08 AM
  2. Single stage refrigeration system optimizing diagram
    By autt in forum System Optimization
    Last Post: 03-12-2008, 03:13 PM
  3. cascade system
    By sagittarius in forum Industrial
    Last Post: 14-03-2008, 11:50 AM
  4. Help for a university refrigeration project
    By uni_student in forum Industrial
    Last Post: 04-03-2008, 02:43 PM
  5. project of refrigeration plant
    By gesi in forum Fundamentals
    Last Post: 12-06-2006, 07:13 AM
