Results 1 to 10 of 10
    luodanwsk's Avatar
    luodanwsk Guest
    Exclamation expansion valves select??
    hello,every one.
    Te=-25c or Te=-20c or Te=-15c,what about to choose the expansion valves ??
    Re: expansion valves select??
    With your expert knowledge as a qualified "jjhhjj" I would have thought that this level of question would have been easily solved by yourself.
    Split Croatia
    6,151
    ¿sıɥʇ ǝuop noʎ pıp ʍoɥ
    "ʎɐqǝ uo pɹɐoqʎǝʞ ɐ ʎnq ı ǝɯıʇ ʇsɐן ǝɥʇ sı sıɥʇ."
    Mar 2009
    KZN, South Africa
    64
    2,212
    ʎsɐǝ ʇou sı sıɥʇ
    Valrico, Florida
    509
    Quote Originally Posted by luodanwsk View Post
    hello,every one.
    I guess your "Home Country" explains the question aeh
    Split Croatia
    6,151
    Last edited by nike123; 12-04-2009 at 03:10 PM. Reason: It was joke, but not sucesful!
    luodanwsk's Avatar
    luodanwsk Guest
    Exclamation Re: expansion valves select??
    everybody !
    my meaning:select the expansion valves in the air -condition (te=2c)? or select the expansion valves in the low- condition (Te=-25c or Te=-20c or Te=-15c)? if Te=-25c select the expansion valves in the air -condition (te=2c),ok????
    Split Croatia
    6,151
    everybody !
    You still asking mind reading from us!
    For what purpose you need to select expansion valve?
    Jun 2001
    N.Ireland
    1,630
    everybody !
    What duty, what operating range (A/C or medium or low temperature) what refrigerant, what condening pressure, what evaporating pressure.
    Kind Regards Andy
    Apr 2009
    Dubai, UAE
    42
    In selecting expansion valve, it is dependent on the pressure drop of your system; evaporating capacity (refrigerating effect) and evaporating temperature.
    In catalogue, there’s always an option of the range of temperature and that temperature refers to your evaporating temperature of your unit. You can refer danfoss catalogue to know more about selecting expansion valves.
  1. Expansion Valves
    By weighman2210 in forum Fundamentals
    Last Post: 11-02-2009, 01:49 PM
  2. Expansion Valves
    By Mukesh in forum Commercial
    Last Post: 19-09-2006, 03:11 AM
  3. Soldering Expansion Valves
    By Abe in forum Domestic
    Last Post: 18-06-2006, 01:07 AM
  4. Internal V's External Expansion Valves
    By Latte in forum Fundamentals
    Last Post: 25-06-2005, 01:12 PM
  5. Expansion valves
    By Martin in forum Technical Discussions
    Last Post: 13-04-2003, 04:50 AM
