Thread: retrofit
    AIRTECH222's Avatar
    AIRTECH222 Guest
    retrofit
    can me somebody help:
    We want to do retrofit on two cooling chillers with axial fans, 30 kw and 200 kw. Now works with R-22.
    With which refrigerant we must do retrofit ? Which spare parts must we replace on chillers when we do retrofit?
    Thank you for quick reply
    Best regards
    Split Croatia
    57
    6,151
    36
    Re: retrofit
    AIRTECH222's Avatar
    AIRTECH222 Guest
    Re: retrofit
    This chillers are for climatisation only cooling, why 404a ?
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: retrofit
    Why retrofit? If they run, let them run.
    Split Croatia
    57
    6,151
    36
    Re: retrofit
    Quote Originally Posted by AIRTECH222 View Post
    That are retrofitting refrigerant. You could also use DROP IN refrigerants.
    Also, you cannot use R407C if you have flooded type evaporator like shell and tube evaporator.
  1. Retrofit on carrier 30bq035
    By cool#9 in forum Air Conditioning
    Last Post: 17-09-2008, 06:46 PM
  2. Sporlan Levelmaster retrofit?
    By Cool2therule in forum NH3
    Last Post: 14-12-2007, 12:38 PM
  3. Retrofit
    By Geofridgee in forum Air Conditioning
    Last Post: 13-07-2007, 03:11 PM
  4. Retrofit
    By environtech in forum Training
    Last Post: 16-05-2007, 06:32 AM
  5. PLC control retrofit
    By Triggerman in forum Technical Speculations
    Last Post: 28-04-2007, 07:13 AM
