Thread: Standard Pressure Readings
08-04-2009, 12:00 AM #1
Good Day Again!
Can you please help me, I need to know what should be the standard pressure reading (suction and discharge) in a compressor installed for a freezer. Thanks.
08-04-2009, 05:20 AM #2
Re: Standard Pressure Readings
Dear Can you let us know which ref you are working with.
08-04-2009, 08:22 AM #3
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Pressures are depending on evaporator and condenser TD and on temperatures inside freezer and in ambient, and last, on used refrigerant.
Evaporator and condenser TD depend on material used and type (passive, forced air) of heat exchanger, conditions of exchanger (clean, dirty, iced etc....), location height from sea level etc.....
08-04-2009, 07:54 PM #4
Benji
By benji in forum Trouble ShootingReplies: 29Last Post: 30-01-2008, 01:25 PM -
Building a wine cabinet
