    Jun 2006
    Question fujitsu wall mount volt free relay
    Can any one help with a fujitsu system (asya09lcc wall mount) and adding this into a city multi m-net cable using a volt free relay off the fujitsu split. I also have daikin splits being added to the m-net using dido units. Using a volt free relay on the daikins but have no wiring diagram for the fujitsu or any back ground experience. All i want to do is switch the units(fujitsu and daikins) on or off via a g50 controller through its time clock, going through a mitsui dido address unit. Any help with mitsui dido's or fujitsu(if they have a volt free relay for fire alarms) would be most appreciated
    Split Croatia
    57
    6,151
    36
    Re: fujitsu wall mount volt free relay
    There is no volt free relay in Fujitsu. If you need to switch off/on Fujitsu, you need to do that by switching on/off power supply of indoor unit.
    Nov 2006
    Cheshire, UK
    56
    360
    You need to set the Fuji unit up for auto restart after power failiure using the switch setting on the internal unit.
    Then use the Volt free control to switch a local contactor feeding the mains power to the Fuji unit.
    This, albeit crude setup, will work as you require.
    He who dies with the most Toys, WINS!
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by sinewave View Post
    Auto restart option is already enabled in that unit and there is no switch for enabling/disabling that function. Although, there is jumper wire on PCB, which, if cut, disables that function.
  1. 12.5 kw wall mount air con
    By Andy W in forum Air Conditioning
    Last Post: 03-10-2009, 09:35 AM
  2. What is the best way to mount a split to a wall?
    By paul_h in forum Air Conditioning
    Last Post: 28-09-2008, 03:57 PM
  3. Fujitsu Split A/C wall unit condensation drain tube
    By Cool 'and Luke in forum Air Conditioning
    Last Post: 21-08-2008, 08:55 AM
  4. Faulty Fujitsu invertor wall split
    By nick_nst@aapt.n in forum Trouble Shooting
    Last Post: 30-06-2008, 08:04 PM
  5. Mitsubishi 10kw Wall Mount Split Impeller?
    By Muggsy in forum Air Conditioning
    Last Post: 22-02-2008, 05:16 PM
