Thread: hunting???
    Mar 2002
    Spain
    67
    23
    hunting???
    Hi;
    Iīm reading an english paper and i donīt understand the following:
    Thermostatic expansion valve operation requiere condensing pressure control, to ensure a minimum pressure-difference over the expansion valve. Too low pressure-differences result in hunting.
    What does hunting mean here??
    Rgrds
    Sep 2003
    ISRAEL
    72
    4,248
    Re: hunting???
    hi Friobernal,
    hunting is a term used to identify the changes in refrigerant flow through the TEV.
    it will open too much, allowing too much refrigerant into the evaporator and then close too much restricting the flow.
    maintaining the condensing pressure high enough, will avoid hunting.
    chemi
    Oct 2003
    5,630
    34
    Aug 2001
    1,046
    Re: hunting???
    Friobernal
    In this context it is term borrowed from the automotive industry that describes an oscillation encountered originally in a poorly adjusted engine timing system that allowed the carburettor to open and close. The engine would speed up and slow down rapidly.
    Used in the context of a TEV it describes either a poorly sized evaporator / TEV combination or a defect in the TEV that allows it to adjust wildly ranging, from flooding to starving the coil. You will see it on your gauges as an oscillation in pressure. There are a number of things that can cause it.
    One thing is certain - you don't want it!
    Hope it helps.
    ________
    Traverse
  1. Hunting Etc.
    By subzero*psia in forum Hobbies
    Last Post: 19-09-2010, 01:40 PM
  2. job hunting
    By neil sailes in forum Chit Chat & Service Stories
    Last Post: 13-10-2005, 09:00 PM
  3. EXV Hunting
    By Dan H in forum Trouble Shooting
    Last Post: 28-06-2005, 09:53 AM
  4. Job hunting...
    By morpheas_24 in forum Chit Chat & Service Stories
    Last Post: 17-06-2002, 11:07 AM
  5. Subcool and Superheat
    By Abe in forum Trouble Shooting
    Last Post: 04-03-2002, 05:50 AM
