    eekool's Avatar
    eekool Guest
    Cooling Load from Forklift
    Re: Refrigerated warehouse
    I am doing heat gain calcs to include forklift operation. What are folks using for a forklift usage factor and a motor load factor? Are the heat gains from the (typically) two motors - traction and lift - additive?
    We have an intermittent, variable operation. I've guessed a 50% usage factor and 50% motor load factor, and added the kw ratings for both motors together.
    I have searched for examples, but can't find any.
    Thanks for your insights.
    Mar 2006
    Merate (LC) - Italy
    52
    2,549
    Re: Cooling Load from Forklift
    Just add the kWh consumed by the battery charger during the night. That's your heat gain.
    If it's a diesel powered forklift, convert the Kgs of fuel consumed into kWh of burnt fuel.
    Split Croatia
    57
    6,151
    36
  1. Cooling Load Calculations
    By hamidpia in forum Tools and Calculators
    Last Post: 05-02-2009, 08:57 PM
  2. Infiltration Cooling Load?
    By Rankin755 in forum Fundamentals
    Last Post: 13-12-2008, 06:26 PM
  3. Heat transfer coefficient - Coolpack
    By Graham in forum Fundamentals
    Last Post: 28-05-2008, 01:08 AM
  4. Compressor loading, cooling, and range of operation.
  5. Cooling Load Calculation
    By jervame_sireh in forum Fundamentals
    Last Post: 21-04-2007, 11:05 PM
