Results 1 to 8 of 8
Thread: R422d
05-04-2009, 10:20 PM #1
R422d
Just done a couple of R22 retrofits onto R422d anyone had any experiences of this, seems to leak more than R22!
05-04-2009, 10:46 PM #2
Re: R422d
Leaks are probably the no 1 problem with this refrigerant when retrofitting from an old R22 system especially with service valve glands, ptfe joints and basically any type of seal including compressor terminals. If you listen to Du Pont or Isceon its a straight forward retrofit when in fact if you do not ensure its leak free on the retrofit you will be back to repair it fairly quickly. There have been one or two articles in the trade press regarding problems with leaks and what companies have done to ensure a leak free system mainly in chillers.
05-04-2009, 10:51 PM #3
Re: R422d
basically its rots seals like crazy
anyone using it ... good luck
06-04-2009, 12:36 AM #4
Re: R422d
Honeywell and WR are using it to replace R22 to some degree of success.
They go into the store mob handed and replace every seal, gland, valve or cap and then
they put the new gas in. All done in a weekend and as far as I
know it is very successful. They had some horror stories early on with seals failing but
now they do a full refit they seem to have sussed it.
Not sure how good the refrigerant is long term but I have not heard of any real problems yet.
taz
06-04-2009, 08:36 AM #5
Re: R422d
Forget R422d. Just wait for recycled R22 to appear on the market and off you go until 2015.
06-04-2009, 09:35 AM #6
Re: R422d
I agree but there will be a price to pay as the big industrial plant owners are buying up recycled R22 and are willing to pay a price premium to ensure supply.
Plus there is a possible amendment to the regs that state 'only recyclable to the original address' plus plus the 2015 ban is potentially being brought forward.
07-04-2009, 09:53 PM #7
Re: R422d
I'm just in the middle of retrofitting a number of my sites at the moment.
All that I can say is all that we left that was original was the Plant and Header Station frames! Apparently its the shape of the molecule that makes this stuff want to leak and it also causes old seals to contract/shrink.
The head temp is lower than R22 so caution needs to be taken if the system has a Sat Gas D/F and all reg valves need to be set correctly.
If the site is surveyed and retrofitted/commissioned correctly I can't see any reason to why this won't be a successful short term interim refrigerant, plus the cost of R22 should soon overtake the cost of R422D.
Would also recommend a good leak detector as ours pick up this refrigerant very well!!!
08-04-2009, 05:09 AM #8
R422D Oil return problems !
By kfjoe in forum Technical DiscussionsReplies: 19Last Post: 26-08-2010, 02:11 PM -
R422D as a R22 replacement
By Mark in forum Supermarket RefrigerationReplies: 5Last Post: 05-09-2008, 07:54 AM -
R422d ???????
By moshman in forum RefrigerantsReplies: 3Last Post: 08-08-2008, 07:25 PM -
R422d replaces R22
By telzen in forum RefrigerantsReplies: 1Last Post: 05-01-2008, 12:40 AM -
HT and LT R22 systems to Isceon MO29 (R422D)
By Steve in forum RefrigerantsReplies: 3Last Post: 02-10-2007, 10:03 PM
