Thread: Airdale wiring diagram needed
04-04-2009, 08:48 PM #1
I`ve got a problem with an Airdale unit (compressor won`t switch off when room reaches temperature). The control panel in a plant room has been messed with over the years so I`m not sure what exactly`s happening with the outdoor unit at various states ie defrost, heating or cooling. Therefore I`m after a detailed wiring diagram for the unit so I can follow the circuit. Airdale`s downloadable (is that a real word?) one is only a connection diagram.
The unit in question is:
CUHS2.5HIEM/01 230v
Hope you can help guys
04-04-2009, 09:16 PM #2
Re: Airdale wiring diagram needed
Hi Glenn.
I don't know the particular unit you are asking about.
But a lot of the Airedale units we look after have a toggle switch within the indoor unit.
With this you can override the controller and operate it in manual mode.
These particular units allow you to switch them off.
(Solenoid valve on the liquid line de-energises and the condensing unit pumps down.)
On this basis of control, you could always test the liquid line solenoid valve supply.
When the system is at temp satisfied the solenoid valve coil should switch off?
And the system pump down?
If this an applicable type of control?
Try it out?
05-04-2009, 10:04 AM #3
Thanks grizzly, I`ll have a look at that.
06-04-2009, 08:06 PM #4
12-04-2009, 10:14 PM #5
A follow on with this problem, the room thermostat is the cheapest one I`ve ever seen and it seems all over the place so I`m intending to replace it with a reliable one so I`ll be sure that the pump`s being controlled properly.
I`m looking for a two stage one, I can`t seem to find on anywhere. Can anyone recommend a good one available in the uk?
Cheers guys
York HICA 600 A51 wiring diagram
By RickSter in forum Air ConditioningReplies: 2Last Post: 06-05-2010, 01:23 AM -
Wiring diagram Carrier
By Martu in forum ElectricalReplies: 2Last Post: 02-04-2009, 11:23 PM -
30 GB wiring diagram
By Jai in forum Air ConditioningReplies: 4Last Post: 17-07-2008, 11:54 AM -
Electrical Wiring Diagram
By bhasadu in forum ElectricalReplies: 0Last Post: 21-06-2008, 09:15 AM -
thermo king kd-11 max wiring diagram for engine
By farmer bob in forum ElectricalReplies: 4Last Post: 04-04-2008, 05:52 PM
